Old June 24th, 2008, 06:36 AM
B767capt is on a distinguished road
Default Neptune electric dryer, no heat
Thought I had this fixed several weeks ago and just got around to testing it. Still no heat. What I have done so far. The heating coil checks good and shows good continunity, no grounding or no short. The left black wire to the coil is only showing 11.8v while the right coil wire is showing 123v. What I have changed on this unit so far is a new circuit board, new motor, the terminal block in the rear where the cord hooks up is new as the old one got hot and the wires melted in two. That is where the unit failed and caused all these problems. I rewired the back with new terminals and bought a new cord. The same old original problem was low voltage to the left black heating element wire. With a new motor which included a new switch for that wire, I don't know why that wire is only getting 11.8 v. Any other components in that line that is restricting voltage? Thanks, Bill
Old June 24th, 2008, 08:16 AM
Hi Bill,
I'm not sure I'm following you so I would like you to check something for me if you don't mind. I see where you said you had to replace the terminal block and cord. With the dryer pluged in, use your volt meter and take a reading at the terminal block between the center wire and the wire on the right and then again between the center wire and the wire on the left. Let me know what you get. I'll need your model number.
Old June 24th, 2008, 08:23 AM
Thanks for replying. Model MDE5500AYW and both outside posts read 123v.
Old June 24th, 2008, 08:27 AM
I just noticed my old original post with the history is just below with my user name B767capt. That has what I have done up to today. I wouldn't have started a new thread if I had seen the old one there. Bill
Neptune has no heat
Old June 24th, 2008, 08:40 AM
What do you read from outside post to outside post?
Old June 24th, 2008, 08:46 AM
245.7v
Old June 24th, 2008, 09:09 AM
I have a service manual for the Neptune dryer but it's too big for here. Click on my name, then click on send me an email. Send me your email address and I'll send you the manual. It's over 150 pages so be patient if you don't have high speed internet.
Old June 24th, 2008, 09:13 AM
email sent.thanks
Old June 24th, 2008, 09:30 AM
Rick you can upload it to savefile.com and I can put it on our server here.
Old June 24th, 2008, 12:53 PM
Jake or Rick if either of you can come up with something let me know. It's puzzling why that black wire to the heat coil is not 123v. I think it comes off the motor aand that is brand new.
Kenmore electric dryer does not heat. fiabeg Sears Kenmore 3 June 3rd, 2008 08:22 PM
kenmore 70 series 110.66712690 electric dryer no heat after some use bkdg100 Sears Kenmore 3 June 29th, 2007 10:53 PM
GE Electric Dryer runs but no heat vdrsolo GE/Hotpoint 1 September 27th, 2006 12:44 PM
Maytag Legacy Electric Dryer --> Popped! Now, No Heat? sundance Maytag/Magic Chef/Admiral/Jenn-Air 3 August 24th, 2006 05:47 PM
Kenmore Elite electric dryer no heat... route62 Sears Kenmore 4 January 10th, 2006 02:40 PM
