2Likes
June 30th, 2008, 07:54 AM
Neptune MLE2000AYW - Works but stops between cycles
Hello!
We have the dreaded Neptune MLE2000AYW which worked great until -just- outside its warranty (a couple of years ago) when it began stopping dead before completion of a load (leaving everything in standing water). I've read about this problem all over the place, the class action suit, etc. Our repair guy did NOT find the usual control board problem... turned out to be a microswitch of some sort (the same kind I have inside my arcade control buttons and buy for like 19 cents). I think the repair cost us almost $300 and nothing about it qualified for any of Maytag's lawsuit coverage, etc. Pretty pissed, obviously.
Everything has worked fine until the last few months. The problem now is that the washer works fine except it stops between almost every cycle. Not EVERY cycle or every load... but MOST loads will stop on on MOST cycles right at the point where the new cycle begins. You just have to keep an eye on it and press the button again. And again. And again.
As I said, sometimes a load will complete entirely from start to finish. But more often that not it will have died between 1 & 2, then maybe 2 & 3, etc. Press the button a moment - it beeps and starts up. Might finish the whole load... might be stopped dead again at the next cycle. It's easy to forget, too, and come back hours later to it just sitting there.
Dryer works fine.
Any thoughts on what I can investigate? I've got the fundamental skills to disassemble and test parts...
- Aaron
June 30th, 2008, 02:20 PM
Hi Aaron,
You may want to check your main control board now for burned spots on it now.
Its located at the top of your dryer, under the top dryer panel.
Here's the repair manual for your Neptune Stackable you can print out:
www.applianceblog.com/manuals/MaytagNeptuneStack.pdf
Manufacturer part#22004325 is RepairClinic item#1032714
November 15th, 2008, 09:04 AM
Sorry to be months replying to this... life has been busy and we've just been putting up with the issue described in my original post above.
Today was a rainy, quiet day and I finally had a chance to remove the Machine Control Board and examine it. Unfortunately, from what I can see, it looks virtually perfect. I don't see any scorching, burning or other oddness around the various components.
I'm about to reassemble everything now and see if anything has changed.
I'm attaching a link to detailed photos of the control board - front and back - if someone with a more experienced eye can glance and tell me if I'm overlooking something.
http://www.halfpress.com/private-files/Neptune/
Assuming I reassemble and the problem hasn't gone away (and I don't know why it would short of a loose connection I'm inadvertently fixing in this process)... any other thoughts?
- Aaron
November 15th, 2008, 09:53 AM
Hi Aaron,
It looks good, but you never know, I've replaced the machine control boards when they look perfect like yours and it fixes the problem.
Another issue with the Neptune's was the motor, they make a new motor conversion kit.
Whats the serial# of your washer? and I can check if yours requires it.
November 15th, 2008, 10:29 AM
Thanks for the quick reply. The model is MLE2000AYW and the serial number I found inside the dryer door is 74860070CT.
Running a load now and, yes, it's stopping between each stage just as it has been for ages now. Irritating...
- Aaron
P.S. Is there any way to get a control board on speculation that is returnable? Possibly secured with a credit card or something? I hate the thought of dropping hundreds of dollars on speculation trying to find the source of the problem.
November 15th, 2008, 12:16 PM
Here's the motor conversion kit for your model:
Manufacturer part#12002039 is RepairClinic item#949491
Check your owners manual, some of these models have a 5-10 year parts warranty on that motor, which includes the motor conversion kit.
Yes, all parts you order from our links here come with a full 365 day money back guarantee even if you installed them and it didn't fix the problem.
November 15th, 2008, 12:29 PM
Good to know on the 365-day guarantee.
Would you suggest I try the board first? Also, can you tell me more about how this motor conversion fits into the problem?
- Aaron
November 15th, 2008, 12:41 PM
Yes, Get the machine control board first, the motor conversion kit also address's this same issue with the motor flaking out in mid-cycle. I always replace both as they go hand in hand with each other.
August 10th, 2010, 01:56 PM
Will the replacement of either/both of these ( control board first, then motor conversion kit ) resolve Non-Dispense issues of Fabric Softener and Bleach for same model?
August 10th, 2010, 05:56 PM
The main control board would. Whats the model# of yours?
By Michael Leonard Woodcock in forum Sears Kenmore
Last Post: July 15th, 2012, 11:09 AM
By lhsman in forum Frigidaire/Electrolux
Last Post: May 23rd, 2012, 10:21 AM
By scleo in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: September 9th, 2011, 10:39 AM
By goodcook in forum Sears Kenmore
Last Post: March 4th, 2011, 10:46 AM
By brinrach in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: January 18th, 2008, 12:08 AM
