July 1st, 2008, 11:21 AM
Jenn-air SVE47500B with dim display panel
Jenn-air SVE47500B
Display illuminates intermittently, so oven, timer, clock and the like only work when the display is working. Sometimes it is dim but all functions in display will work. Unit is 10 years old.
I’ve read posts on board and seems problem may be control board.
Any opinions?
July 1st, 2008, 02:49 PM
Hi Ron,
Yes, you'll need a new clock control board assembly.
Here's cheapest one I found for your model:
Part Number: AP367441 - Manufacturer's Number: 71001799
July 4th, 2008, 07:10 PM
Thanks, I'll order one on Monday.
July 4th, 2008, 10:55 PM
Ok, sounds good Ron, let us know how it goes.
July 6th, 2008, 04:57 PM
I have (almost) the same problem -- my display is dead! I'll order the same part -- but can you give me a link to instructions for installing it?
Many thanks!
July 6th, 2008, 06:23 PM
Here's the repair manual for this model, it shows you how in the Control Panel Access section:
www.applianceblog.com/manuals/16010191.pdf
July 7th, 2008, 04:55 AM
Great! Thanks for the speedy response!
July 7th, 2008, 08:18 AM
Glad to help.
July 9th, 2008, 04:47 PM
UPS just dropped of the part. I installed it and everything works great.
It's real easy to remove front plate, take off knobs then all 8 screws holding parts that the knobs attach too, then two screws holding endplates, and then I think it was 4 or 5 more screws to remove whole plate. You will then see part you need to swap out.
Thanks for all the great help.
July 9th, 2008, 05:26 PM
Excellent, good job Ron fixing it.
By mangowhirlpooltango in forum Whirlpool/Roper
Last Post: March 10th, 2008, 11:04 PM
By Rick H in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: December 4th, 2007, 08:51 PM
By DrDave1958 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: November 1st, 2007, 09:22 PM
By Arnhemjim in forum KitchenAid
Last Post: June 10th, 2007, 08:41 PM
