Old July 5th, 2008, 06:23 AM
asand211 is on a distinguished road
Default Maytag PYE3300AYW Electric with intermittent heat
Dryer started to only heat intermittently a few days ago. It seems to work on one cycle and then not on the next few. My wife figured out that if you move the temp control knob to air fluff and then back to heat it seems to cause the dryer to heat on that cycle. Sounds like the switch could be faulty but I want to be sure before ordering a new one.
Old July 5th, 2008, 06:57 AM
That definitely sounds like the problem.
Its very inexpensive, here's the temp. switch for your model:
Manufacturer's Number: 31001447
icon
icon
icon31001447
Old July 5th, 2008, 07:01 AM
Default Thank you so much Jake
I'll get it ordered!
Old July 5th, 2008, 07:09 AM
Glad to help, let us know how it goes when you get it installed.
Old July 5th, 2008, 07:12 AM
Oops, I just noticed it was Out-of-Stock there.
Its in Stock here, just a few dollars more:
Manufacturer part#31001447 is RepairClinic item#487880
Old July 5th, 2008, 07:58 AM
Default Placed order
and I'll let you know!
Old July 9th, 2008, 02:31 PM
Default Jake, need your assistance please
The new switch came in today and I think it might be the wrong one unless the style has slightly changed. The number on the back of the old switch is 53-3533 ASR4367-217T and on the new switch the number is 53-3576 ASR4373-513T.
Also, the connections are slightly different. Both switches have a total of 5 connections(red wire top, blue wire bottom left, yellow bottom right, and two bottom center for the capacitor). The difference is that on the old switch the left center capacitor connection is connected to the blue wire connector, whereas, on the new switch it is a separate connection that disappears into the switch.
Is this the wrong part?
Old July 9th, 2008, 03:20 PM
Yes, I double checked it.
Contact RepairClinic to verify with them.
800-269-2609
Contact Us
8 am to midnight-ET
Seven days a week
Old July 9th, 2008, 03:29 PM
Default Yes it is the wrong part?
Sorry, I misunderstood.
Old July 9th, 2008, 04:15 PM
Its the correct part I meant, sorry.
RepairClinic may have shipped you the wrong one by accident.
Kenmore electric dryer does not heat. fiabeg Sears Kenmore 3 June 3rd, 2008 08:22 PM
Maytag PYG2300AWW Intermittent heat jducey Maytag/Magic Chef/Admiral/Jenn-Air 3 November 18th, 2007 10:44 PM
Maytag Dryer MDE7460AYQ - intermittent heat stevelee1954 Maytag/Magic Chef/Admiral/Jenn-Air 4 July 23rd, 2007 12:13 PM
Maytag Legacy Electric Dryer --> Popped! Now, No Heat? sundance Maytag/Magic Chef/Admiral/Jenn-Air 3 August 24th, 2006 05:47 PM
Maytag Electric Dryer DE482 does not heat jumpu Maytag/Magic Chef/Admiral/Jenn-Air 1 February 1st, 2006 10:49 PM
