Old September 18th, 2005, 11:01 AM
paulrhodes is on a distinguished road
Default Spray Arms not Spinning on Maytag MDB9600AWB Dishwasher
The spray arms have stopped spinning on my Maytag MDB9600AWB dishwasher.
The dishwasher fills up to the heating element.
It runs through the entire cycle and drains properly.
The wash motor comes on and runs okay but does not seem to pump any water to the spray arms.
I removed the large plastic section that runs from the pump area up the inside back of the tub to the top arm - it was clean with no obstructions.
I removed the lower spray arm and the cover below it, the impeller assembly, and the large assembly that has what appears to be fine filter material around the top. Everything was clean and nothing was clogged.
At that point I was down to the motor shaft and didn't go any further.
I reassembled everything and the problem is still there...not surprisingly since I didn't fix anything.
I would very much appreciate any suggestions?
The dishwasher is about 18 months old.
It was working fine until now.
Thank you
Old September 19th, 2005, 03:52 AM
Post on the wash motor may be cracked and this slows down the wash impellor so we get poor pressure.
WASH MOTOR SEAL KIT (Series 10)
http://www.repairclinic.com/referral...=153&N=1025846
WASH MOTOR SEAL KIT (Series 20)
http://www.repairclinic.com/referral...=153&N=1035877
First 2 digits of your serial # is the series.
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Maytag dishwasher for parts beginnersluck Buy, Sell or Trade 0 February 25th, 2007 01:34 PM
Kenmore 587.15152400 dishwasher top spray arm not working eprosenx Sears Kenmore 3 December 14th, 2006 07:23 PM
how to clean holes in spray arms? ericmj Maytag/Magic Chef/Admiral/Jenn-Air 3 July 27th, 2006 08:12 AM
No water coming from spray arms Denise Hart KitchenAid 3 June 12th, 2006 11:08 PM
Frigidaire Dishwasher spray arms are dry Wood-Coach Frigidaire/Electrolux 1 April 5th, 2006 10:32 PM
