Old August 1st, 2008, 08:55 PM
draasch is on a distinguished road
Angry Mzd2752grq
my fridge is less than 5 yrs old. i came home from the fire house today and found a puddle on the floor. the fridge was kind enough to stop working while i was working a 24 hour shift. the fan is running, but the compressor is not kicking on.....i lost everything inside....any ideas as to why or what the fix might be???????
Old August 2nd, 2008, 12:52 AM
Which fan is running both the freezer fan, and the condenser fan in the back of your refrigerator that sits next to your compressor?
If both fans are running good, then 2 Things would cause this issue.
1. Your compressor start relay has gone bad.
Unplug your refrigerator first!
You would need to pull your refrigerator out from the wall, then take the lower back access cover off, then take off your start relay assembly#4 here(take the wires off first, make sure you mark down were your wires go):
Then shake your start relay assembly, if you hear it rattle inside, then its bad.
If it doesn't rattle then ohm test it for continuity with an ohm meter.
Whats the serial# of your refrigerator? As your model has 2 different start relay's.
Old August 2nd, 2008, 06:32 AM
Default relay
ser. # 14862312CG
the relay is bad. i took it off and pieces started to fall out of it. it smells burnt too. i will look for one today.
thanks again for all your help. u saved the rest of my hair from falling out!
Old August 2nd, 2008, 09:16 AM
Ok, Glad you found out that was the problem.
Here's the start relay for your model:
If your serial# on your refrigerator starts with 10-22 you need this one:
Manufacturer's Number: 12002784
If it starts with 23 or higher you need this one:
Manufacturer's Number: 12002794
So since your serial# starts with 14 you would need the first one listed.
Old August 2nd, 2008, 12:45 PM
thanks for all yur help, i got the new part this morning and installed it. seems to be working fine so far...............................
thanks again,
david
Old August 3rd, 2008, 12:00 AM
Sounds good David, good job.
Creaking Noise from Maytag MZD2752GRQ J. Leland Maytag/Magic Chef/Admiral/Jenn-Air 2 March 8th, 2007 01:42 PM
