August 21st, 2008, 05:59 PM
MAH5500BWW Issues
My parents have a Maytag MAH5500BWW. The issue is on going and I am not sure what it could be.
This is the problem, at the last cycle it will not drain or spin. It is a hit and miss thing but mostly miss.
I cracked it open today and did not find and bad wiring. There are no error messages that appear. The lines are not clogged.
I tested the lid switch. I opened the door and held in the button and it gave me the OD (open door). Closed the door and it works fine.
I ran three test on it. I did the rinse cycle which takes about 12 mins., I did the light soil twice.
Rinse cycle started at 12 mins, filled with water and that is it, it did not spin or drain. I seemed to be last or out of time.
Did the light soil with a light load and it started at 43 mins like normal and it agitated (spin back and forth), around the 30 min mark it did spin and drain. It did that till it got to the end around 8 or 7 minutes, and it did spin and drain and finished like normal, load was stuck to the side and not wet.
I did the same thing (cycle and load amount) second time. It got down to the 8 min mark and just danced around the 7 - 8 min mark. did not spin or drain.
When it does spin , it spins, and when it drains it does drain.
I am not for sure where to take it from here, should I start replacing parts?
Thank you,
David
August 21st, 2008, 09:32 PM
Hi David,
There's been many issues with the main control board and motor conversion kit on this model.
Here's the online repair manual for your model, Your model starts at page#107:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Whats the serial# of your washer?
August 22nd, 2008, 07:05 AM
Thank you Jake. I will get the serial# and get back with you.
David
August 22nd, 2008, 09:44 PM
Ok, sounds good David.
August 23rd, 2008, 09:01 AM
Sorry Jake I did not get the Serial # yet, going back over there today. But I did do all the service testing and it past everything and did everything. Does that mean anything?
August 23rd, 2008, 09:48 AM
Nope, doesn't mean anything, still can have intermittent problems.
August 26th, 2008, 02:31 PM
Sorry for the wait.
The serial number is 71767180ZM
Again thank you for your help.
August 26th, 2008, 08:32 PM
Thanks David,
Here's the control panel console assembly for your model:
Manufacturer part number 22003238 is RepairClinic item number 824620
22003238
Manufacturer part number 22004299 is RepairClinic item number 1032966
22004299
August 27th, 2008, 07:36 AM
August 27th, 2008, 09:31 AM
Yes, the control board.
99% of the time its just the control board, but I had one were it fooled me and it was the control panel. So you can order both and return the one you don't need for a full refund if you want.
By powerbowlers in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: May 14th, 2012, 06:15 PM
By artzypantz in forum Frigidaire/Electrolux
Last Post: May 11th, 2008, 10:50 PM
Last Post: December 3rd, 2007, 12:08 PM
By smurphnet in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: March 20th, 2007, 03:47 PM
By this_is_nascar in forum Sears Kenmore
Last Post: November 24th, 2005, 08:08 PM
