A friend has a Magic Chef model #CER1360AWW range. Her bake element burned out, The whole front of it burned. She had someone replace the element & now it will not heat. I checked voltage to the element with the thermostat on. I don't get 240 volts to the element. The indicator light comes on & the stat clicks when you cut it on, but no 240. I get 120 volts on each leg. There is 240 volts at the terminal block. It has the manual stat & digital clock & timer. Does she have a bad stat or timer/clock? Thanks.
Hi shadowrider,
Now you have 240 volts across both 120 volt legs at the range terminal block? If so, then I'd say your electronic clock control board is bad. They make 2 different ones for this model, please post the serial# of the range to get you the correct one. Jake
Jake, I do have 240 at the terminal block. Only 120 volts at the bake unit with stat on. I'll get a serial & post it asap. Thanks.
Ricky |
| Magic Chef Range | radagast8 | Maytag/Magic Chef/Admiral/Jenn-Air | 2 | February 29th, 2008 11:08 PM |
| Magic Chef range timer continually going off | petlover1 | Maytag/Magic Chef/Admiral/Jenn-Air | 3 | December 9th, 2007 09:15 PM |
| Running Fan Magic Chef Range | KD6NUJ | Maytag/Magic Chef/Admiral/Jenn-Air | 4 | November 24th, 2007 06:27 PM |
| Magic Chef range w/o error code? fuse? | heatherolah | Maytag/Magic Chef/Admiral/Jenn-Air | 3 | April 18th, 2007 08:31 AM |
| Magic Chef Gas range | moscafj | Maytag/Magic Chef/Admiral/Jenn-Air | 10 | December 23rd, 2005 11:48 PM |
