Maytag Dishwasher: MDB7601AWW
Age: 18 months Problem: For a normal wash cycle the display has always shown "97" as in minutes. Now it shows "2H" as in 2 hours. What I have done: 1) reset the circuit breaker (leaving off for a couple of minutes) 2) completed manual function test - results: appears OK 3) completed field service test - results: appears OK The sheet that contains the function tests has the cycle descriptions inside. A normal wash goes from 97 to 117 minutes and I get how 117 minutes shows up as "2H". The only thing that I have noticed over the last couple of weeks is that it doesn't appear to steam quite as much (relative term) at the end of the process and sometimes the dishes don't seem completely dry. I'm not sure if this last comment is completely valid or not. Any thoughts on the time difference in the display? Thanks in advance for your help. raythepa |
Hi raythepa,
Did you do both the Manual Function Test and Field Service Test on page#5 here: http://www.servicematters.com/maytag...s/16026393.pdf Jake
Ok, just saw that you did.
I would now ohm your heating element with an ohm meter, normal reading will be 30 ohms or less. If it ohms good, then its likely a control board problem. Here's the cheapest control board I found for your model: Manufacturer's Number: 12002710 Jake
So now i'm into new territory, do i use the ohm meter directly on the heating element or will i need to expose the control board and use the test procedure on Page 4 of the document you sent? If yes, is the schematic on page 6 the one to follow.
For me i'm considering this a DIY project. I should be able to do what your suggesting without deferring to a service call? Ray p.s I'm well aware that I proceed with caution at my own peril. Sounds serious but I just wanted to get that out there. |
I figured it out ohms were good (1-2, barely moved off zero).
Have replaced panel and will purchase control board. While I'm waiting for the part i will also contact Maytag just in case they will give me credit since the unit is only 18 months old. |
![]() Quote:
| Maytag MDB7601AWW Unresponsive Control Panel | baileyshbr | Maytag/Magic Chef/Admiral/Jenn-Air | 5 | September 20th, 2008 03:07 PM |
| Maytag MDB7601AWW Grind Noise | baileyshbr | Maytag/Magic Chef/Admiral/Jenn-Air | 3 | March 9th, 2008 11:36 AM |
| Maytag MGR5770ADW display screen says off ?? | 68PonyGirl | Maytag/Magic Chef/Admiral/Jenn-Air | 2 | September 14th, 2007 06:56 AM |
| Maytag Dishwasher MDB6100AWW blinking display lights and won't run? | chip718 | Maytag/Magic Chef/Admiral/Jenn-Air | 1 | May 10th, 2007 08:43 AM |
| maytag part# question | sun45 | Maytag/Magic Chef/Admiral/Jenn-Air | 1 | July 28th, 2006 04:45 AM |
