September 23rd, 2005, 02:29 PM
Maytag Dryer Drum Squeak
First timer here, so be easy on me! ;-)
I've got a Maytag dryer that squeaks as the drum turns. First, I tried to spray WD-40 on the pullies that guide the belt around the drum, but that didn't do it.
With the power cord pulled from the outlet, I pulled off the front panel and then the 2 screws that hold the top on, got the top out of the way, and lightly wiggled the drum. I can hear the squeak coming from the back of the drum.
Where could this squeak be coming from? I'm hoping I don't have to pull the drum out to WD40 whatever it is that's squeaking.
September 23rd, 2005, 02:45 PM
Continuing to investigate... There's an idler pulley (?) in the back, lower right side. If I grab that and pull/push on it, the squeak can be duplicated. I'll try to spray some WD-40 on that, although it doesn't look like anything move other than the pully. If I wiggle the pulley, no squeak. So, it's the thing the pulley attaches to...
Any thoughts?
September 23rd, 2005, 03:21 PM
Alright - all done....
It wasn't the pulley attachment. Picture this: there's the ignitor and gas valve and the flame moves through the 4 inch (?) tube to the rear of the dryer... then the heat goes up the back of the dryer via some rectangular duct, etc... Where the 4 inch tube meets the part that goes up the back of the dryer. That's where the squeak came from. The 4 inch tube sits in the rectangular duct and rubs. It became a squeak. I forced a nail between the tube and the "receiver" and wiggled everything around. No squeak. I put it all back together and ran it for about 10 minute - No more squeak!!
Yea!
September 23rd, 2005, 10:53 PM
Great job Bikerbill7!
Glad you got it fixed!
Thanks for the update,
By Jann K in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: December 3rd, 2007, 07:41 PM
By rlsmith in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: January 6th, 2007, 03:29 PM
By justlearning in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: November 27th, 2006, 06:55 PM
By DaveS in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: August 9th, 2006, 02:50 PM
By marilano in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: September 5th, 2005, 02:03 PM
