October 14th, 2008, 11:15 AM
Maytag Neptune MAH5500BWW won't spin
Hi, I know this has been discussed before but I just wanted to have a confirmation that what I've read was correct.
My Maytag Neptune (model MAH5500BWW) does not spin. Everything looks good, it powers up, will do everthing else but it won't spin. Sometimes it takes around 60 sec for it to unlock the door after "not spinning".
I think I should order motor / control board, am I right?
Serial : 71780526ZK
October 14th, 2008, 02:32 PM
Yes, thats what you would need.
Does it drain the water first before it tries to spin?
Manufacturer part#12002039 is RepairClinic item#949491
Check your owners manual, some of these models have a 5-10 year parts warranty on that motor.
October 14th, 2008, 02:44 PM
Thanks for your fast reply!
No, it does not. Actually, all it does is fill with water then I can hear an humming noice (like a motor trying to start) every ~15 sec that lasts for ~5 sec.
I don't know if that gives you any hint but this is probably a canadian model since I'm in Canada. I've already contacted repairclinic.com where you seem to redirect clients to and they do not ship to Canada, any ideas?
October 14th, 2008, 04:54 PM
Ok, then you'll need to get that part locally at an appliance parts store in your area.
Here's a link to an appliance parts store in your area:
http://www.reliableparts.ca/locations/quebec.cfm
By powerbowlers in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: May 14th, 2012, 06:15 PM
By trouble353 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: November 16th, 2006, 07:13 PM
By chanwsc in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: September 13th, 2006, 11:16 PM
By fox_1028 in forum Maytag/Jenn-Air Reviews
Last Post: May 24th, 2006, 09:15 AM
By CrossmenTop3 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: April 1st, 2006, 03:39 PM
