October 27th, 2008, 04:17 PM
Jenn Air Oven Won't Heat
I have a Jenn Air Model #SVE47600W range. The oven will not heat. When you press Bake (or Broil) on the touch pad and a temp is selected - Pre-heat is displayed and 100 degrees is shown as the temperature (except in the case of Broil which displays "HI"). The oven does not heat and the display remains the same. There are no error codes displayed. This problem happened before but the oven finally started heating in those instances. Now nothing.
October 27th, 2008, 07:23 PM
I've run into this issue a couple of times, I always first check the hi-limit thermostat to make sure it has continuity with an ohm meter. Unplug or turn the breaker off to your range first before you check it, then take both wires off of it.
Here's the hi-limit thermostat for your model:
Manufacturer part number 74009837 is RepairClinic item number 1072642
If that checks good then its the relay board thats bad. Both of these parts are located in the very back of your range, behind the back access panel.
Here's the relay board for your model:
Manufacturer part#12001691 is RepairClinic item#400658
By nameit23 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: June 19th, 2008, 07:15 PM
By sun45 in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: April 3rd, 2008, 08:02 AM
By tshurd in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: March 12th, 2008, 10:26 AM
By nyrend in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: September 28th, 2007, 12:19 PM
By AFH in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: November 3rd, 2006, 10:52 AM
