Old November 11th, 2008, 06:23 PM
gobucks is on a distinguished road
Default Replacing Maytag Dishwasher Door Latch
Model Number. MDBH970AWS.
Door Handle/Latch Assembly is broken and currently in the process of replacing. This is actually the 2nd time doing this (1st time was 2 years ago).
1st time wasn't too bad as I was able to transfer the microswitches from one assembly to the other but this time:
When removing the microswitches (little red/black switches) from the door latch, one of them popped open and spilled out their guts (never to be seen again).
New assembly has the switches included so that isn't a big deal however now I will need to remove the wires from the terminal of the old microswitch. I have seen this question posted all of the web and usually the reply is just:
1) Pull hard
2) use a screw driver or plyers.
I just don't see how these terminals are going to be released. I can pull harder but I have already started a stress crack in the plastic housing. I don't see anything in the housing that will release the terminal if pressed in. Pictures are attached.
Am I missing something or have others been talking about another part?
Replacing Maytag Dishwasher Door Latch-terminals-need-removed.jpg.jpg   Replacing Maytag Dishwasher Door Latch-picture-microswitch-reattached-no-guts-inside.jpg.jpg
Old November 11th, 2008, 06:37 PM
Never Mind.
I gave it the college try one more time after posting the thread. Sure enough they do come out. Can't believe you have to pull that hard. Ended up cracking up a knuckle doing it.......
Old November 11th, 2008, 07:04 PM
Yes, its always amazed me why do they need to make them so hard to get off, I've changed many of these door latches and the wire connectors are always hard to get off, I pry them off with a flathead screwdriver or needle-nose pliers.
Good job getting the wire connectors off.
Here's the door latch assembly for your model in case others need to order it as well:
Manufacturer part number 99003347 is RepairClinic item number 1154665
99003347
Maytag Performa dishwasher PDB4600AWX won't drain Czum Maytag/Magic Chef/Admiral/Jenn-Air 3 October 14th, 2008 08:56 AM
Maytag Model MDB7100 Dishwasher Recall nbrsguy Maytag Brands Forum 2 June 13th, 2007 04:58 PM
Maytag dishwasher for parts beginnersluck Buy, Sell or Trade 0 February 25th, 2007 01:34 PM
Maytag Dishwasher DWU8402AAE Stalls wally1314 Maytag/Magic Chef/Admiral/Jenn-Air 1 August 31st, 2006 09:48 AM
Spray Arms not Spinning on Maytag MDB9600AWB Dishwasher paulrhodes Maytag/Magic Chef/Admiral/Jenn-Air 1 September 19th, 2005 03:52 AM
