Old December 3rd, 2008, 08:14 AM
mike_thomsss is on a distinguished road
Default Maytag MZD2766GE* ice maker stopped working
We went on vacation for Thanksgviing and turned off the main water line to our house. When we got back 6 days later and turned the water back on, we discovered that the ice maker was no longer working.
I think there's no water getting to it. We can hear it operating/moving the little arms up and down, but no ice is being produced.
There seemed to be air in the water lines after turning the water back on. That is, when I ran the water in the kitchen or other sinks, the stream would "spit" a little, as it cleared the air from the lines. But it's been several days now. There is no more air in the lines, but the ice maker still isn't working.
Please help...my wife needs her gin & tonics!
I found this thread which seemed to be a similar problem, but I didn't see any resolution.
Maytag ice maker not working
Old December 3rd, 2008, 10:46 AM
Hi Mike,
The reason that happens is whenever you turn the water off to your refrigerator or house, you also have to turn your ice maker off, as it will try to make ice without any water going to it, thus it builds up an ice clog in your fill spout#34 here:
You'll need to clear your fill spout, its located in the back of your ice maker.
You'll probably need to take the ice maker out to get access to it. Use a hair dryer to unclog it.
Old December 5th, 2008, 11:49 AM
Thanks Jake! I'll be tackling it this weekend and will let you know the results.
Old December 5th, 2008, 12:48 PM
Ok, sounds good Mike.
Old January 17th, 2009, 03:30 PM
Jake, thanks again for the guidance, but I managed to fix the issue without having to take anything apart.
After delaying a fix for over a month now, my wife couldn't take it anymore. So I realized I could move everything (food) in the freezer to our garage freezer and then turn the setting for the freezer temp all the way to off. I did that and left the freezer door open for about 6 hours (putting a lot of towels in and around the freezer in case of lots of melting). Then I turned the setting back up to normal, and the ice maker is working again! I think that was a lot less painful than taking anything apart.
Thanks for your help, I was definitely going to follow your instructions if thawing it out didn't work!
Old January 17th, 2009, 09:11 PM
Ok, sounds good Mike, glad its working good again.
Complete Ice Maker Assembly - For In-Door Ice Models Jake Refrigerators & Freezers 0 April 29th, 2008 12:56 AM
Ice Maker Not Working: KitcheAid Superba Hookem KitchenAid 1 February 2nd, 2008 05:05 PM
Superba Ice Maker stopped working. I think I know problem but need confirmation rockjeep44 KitchenAid 10 June 28th, 2007 01:01 PM
Kenmore Coldspot Ice Maker Stopped Working Izumino Sears Kenmore 5 March 11th, 2007 09:58 AM
Whirlpool Ice Maker Stopped Working Sri Whirlpool 9 September 14th, 2006 12:23 AM
