Old December 4th, 2008, 08:33 PM
q2quest is on a distinguished road
Default Where is the adaptive defrost control board located?
Hello-
I have determined I need an adaptive defrost control board for my Jenn Air refridgerator with the freezer on the bottom. Thanks to this forum I found out what the problem was based on the frost inside the freezer. Can anyone tell me where this item is located? Thanks
Old December 4th, 2008, 11:01 PM
Whats the model# of your refrigerator? and I can tell you. The model# tag is located inside the refrigerator section on the upper walls or ceiling.
Old December 5th, 2008, 08:48 AM
Default Model #
Our model # is JFC2087HRP. It's a Jenn Air french door model.
Thanks.
Old December 5th, 2008, 12:01 PM
Here's the one for your model you can order(comes with installation instructions):
Manufacturer part number W10165748 is RepairClinic item number 1455147
W10165748
Its #5 here, its in your temp. control console:
Old December 5th, 2008, 06:15 PM
Jake-
Thank you very much. I'm a little confused, though. I have to replace the entire temp. control board? The controls appear to be functioning fine otherwise and the little trap door in the refrigerator compartment opens and closes as it should, but I did have a lot of frost in the back of the freezer. Thanks
Old December 5th, 2008, 08:24 PM
Yes, your adaptive defrost control is integrated into the temp. control board on your model.
Before you replace it, did you run the diagnostics mode on it for Forced Defrost?
Here's the tech. data sheet that explains how to do it:
http://www.servicematters.com/maytag...s/16027044.pdf
When you put it in Forced Defrost, let it stay in that mode for awhile and then check under your evaporator coil in the freezer to make sure the defrost heater is on.
If it starts defrosting properly and the defrost heater is on, then we know for sure your temp. control board will need to be replaced.
Let us know what happens.
Old December 5th, 2008, 09:27 PM
Thank you so much. I will follow the instructions.
Old December 5th, 2008, 10:23 PM
motor, motor control or control board??? bosshogg Maytag/Magic Chef/Admiral/Jenn-Air 5 June 21st, 2007 12:02 PM
bottom freezer, locate, replace adaptive defrost board kro Sears Kenmore 12 December 14th, 2006 02:59 PM
GE JVM2070SK - 2nd control board dead dfenwick GE/Hotpoint 2 July 4th, 2006 12:24 AM
Maytag Adaptive Defrost Control schematic rlbatch Maytag/Magic Chef/Admiral/Jenn-Air 10 October 21st, 2005 12:56 AM
Adaptive Defrost Control Board...again? kabernard Refrigerators & Freezers 1 April 28th, 2005 10:55 PM
