Old December 6th, 2008, 06:49 AM
wiznkids is on a distinguished road
Default Maytag Neptune Dryer MDG4000BWW is NOISY
This morning my wife woke me and shared with me that something was wrong with the dryer. Great start to the weekend! She said when she started the dryer, it began to spin, but then she heard a loud clunk and it stopped. When I checked it out a few hours later, I turned it on. It came on and the drum rotated but it was noisy. It made multiple clicking noises and a rhythmic knocking noise. I quickly shut it off. When you rotate the drum by hand, it pretty much make the same noises.
I'm a do it your-selfer, but not to the degree this might require. Last time I played with a dryer was 1990 and I replaced a thermostat. Not a big deal, but that was when they looked easier to get into. I could see spending $200 -$300 on paying someone to repair it, versus me spending a day or so messing with it.
Based on what I'm telling you, what's your thoughts? Based on what it sounds like, do you think it's worth repairing by a repair person? I believe we purchasaed it new in 2000.
Thanx for your imput.
Old December 6th, 2008, 07:12 AM
Whats the serial# of your dryer? Its located inside the door on the model# tag.
Possibly your blower wheel or rear rollers.
Here's a help link that shows you how to take it apart to check inside it(UNPLUG YOUR DRYER FIRST):
http://www.applianceaid.com/may-apart.html#new-door
When you get the drum out, turn the motor pulley and see if you hear the noise, then turn the rear rollers.
Old December 6th, 2008, 07:30 AM
Serial Number: 28804763YF
My wife said when she tried to start it this morning, as I described in my post, she said it sounded as though "something dropped".
Old December 6th, 2008, 07:45 AM
Also, nothing comes up in the parts list from that link for rollers. Do you mean tumblers?
Old December 6th, 2008, 08:16 AM
Before I went to disconnect the belts I decided to turn the drum first. When I did I saw the problem. The blower wheel cracked in half and the shaft spins i what's left of the wheel housing. Do you think there's a need to explore further?
Old December 6th, 2008, 10:00 AM
Do you know what would cause the blower wheel to break into?
Since I'm here, should I replace anything else? The rollers can be worn, right? How do you tell if they are worn to the point they should be replaced? What about the belt? Since it's not all that difficult to get to these parts, should I let them wear further? Or can I damage something else if I let them go?
Old December 6th, 2008, 07:16 PM
Sorry for the delay, Had to go out with Family today.
Yes, its common for the blower wheel to just wear out and break like that.
Here's the blower wheel for your model you can order:
Manufacturer's Number: 33001790
33001790
The drum rollers are #24 here, you should have 2 on each side in the back of your dryer drum:
Yes, the rollers can get worn, you change change them while you have it apart.
Here's the dryer drum roller for your model:
Manufacturer's Number: 12001541
12001541
Here's the belt as well #18:
Manufacturer's Number: 33002535
icon
icon
icon33002535
So, it would be like giving it a tune-up while you have it apart.
Maytag Neptune Dryer Doesn't Heat - MLE2000AYW brinrach Maytag/Magic Chef/Admiral/Jenn-Air 3 January 17th, 2008 11:08 PM
Maytag Neptune Dryer Lights are on but nobody's home noder Maytag/Magic Chef/Admiral/Jenn-Air 6 July 23rd, 2007 10:04 AM
maytag neptune dryer not working stacie Maytag/Magic Chef/Admiral/Jenn-Air 3 April 12th, 2007 10:22 AM
Maytag Neptune Dryer cleo Maytag/Magic Chef/Admiral/Jenn-Air 1 January 22nd, 2006 01:29 PM
Maytag dryer noisy and hot KenR Maytag/Magic Chef/Admiral/Jenn-Air 1 August 18th, 2005 04:09 AM
