Old January 1st, 2009, 10:25 AM
brewski is on a distinguished road
Question [FIXED] Maytag fridge stopped cooling
I have a Maytag PTB1953GR fridge that quit cooling a couple days ago. The compressor kicks on for about a second or two, then it sounds like a breaker clicks (maybe the thermal overload?) and the compressor shuts off for a few minutes, then the process repeats.
Old January 1st, 2009, 11:18 AM
Yes, remove the start device relay from the side of your compressor, make down wire the wires go first, then once its off, shake it and see if it rattles inside, if so its bad.
Here's the start device relay kit you can order:
Manufacturer part number 12002782 is RepairClinic item number 1194680
12002782
brewski (January 1st, 2009)
Old January 1st, 2009, 06:47 PM
Default My parts look different.
Just to clarify. I have a part that rattles a little. It looks different from what you're showing me. The part that I have mounts where the red circle and arrow are. Is this the right part?
[FIXED] Maytag fridge stopped cooling-img_4747.jpg   [FIXED] Maytag fridge stopped cooling-img_4744.jpg   [FIXED] Maytag fridge stopped cooling-img_4745.jpg   [FIXED] Maytag fridge stopped cooling-img_4746.jpg
Old January 1st, 2009, 07:15 PM
Yes, thats it. Yes it does look different, but according to your model# thats the replacement kit for it that I linked to it above.
If you have an ohm meter you can also check it for continuity.
It shouldn't rattle at all, so your saying it rattles a little? Is likely bad then.
Old January 3rd, 2009, 11:53 AM
Default New part instructions
I picked up the part at a local appliance shop (they had it in stock, and I've got two little boys to feed) And the instructions that came with it direct me to use wires and terminals that don't exist on my wire harness.
I took the old starter/overload unit apart and noticed that the part that rattles is identical to one of the pieces in the kit (the one in the kit does not rattle). Can I just swap that part out?
Old January 3rd, 2009, 02:18 PM
Default More Info
I was using the Repair Clinic website and when I looked up my model number I found the following part:
http://www.repairclinic.com/referral...1265&N=1005689
This part looks identical to the one that came off of my compressor. Is this the part I should be getting? Should I also be replacing the capacitor that plugs into the back of it?
This is the capacitor:
http://www.repairclinic.com/referral...=1265&N=674876
Old January 3rd, 2009, 10:24 PM
Yes, I didn't see that one listed, but it is the original one for your model, its ok to use that original one:
http://www.repairclinic.com/referral.asp?R=1265&N=1005689
The one I linked you too above is the replacement kit, so it will be more work/steps installing that one.
You can exchange the one I told you to get for the original one if you want.
You can get the capacitor as well.
brewski (January 5th, 2009)
Old January 5th, 2009, 07:12 PM
Default I got it figured out, I think.
I got the relay and thermal overload unit installed, and the fridge is running. However, if I put the cover over the relay, it does the same thing it was doing originally. Not sure why, but I think I can live knowing that cover isn't there. Shouldn't be too big of a problem should it?
Old January 5th, 2009, 08:40 PM
Yes, its fine to leave the cover off.
Maytag Plus MTB2156BEW Fridge section not cooling properly JimBenjamin Maytag/Magic Chef/Admiral/Jenn-Air 8 October 23rd, 2007 11:18 AM
Maytag MBB1954GES fridge no longer cooling tonystandefer Maytag/Magic Chef/Admiral/Jenn-Air 11 August 24th, 2007 10:10 AM
i have a maytag model MZD2766GEB fridge not cooling nubsy Maytag/Magic Chef/Admiral/Jenn-Air 7 April 28th, 2007 11:30 AM
Maytag MZD2766GE Not Cooling Fridge Tanjima Maytag/Magic Chef/Admiral/Jenn-Air 5 November 14th, 2006 05:34 PM
