Old January 13th, 2009, 03:50 PM
jennidbell is on a distinguished road
Default [FIXED] Admiral refrigerator not cooling properly
model # AS22N8D It's a side by side. The freezer is working fine. The refrigerator isn't as cool as it should be. The milk, drinks, etc aren't cold like they were. Everything is staying somewhat cool, but it's turned up all of the way, and it's just not like it was. Any ideas?
Old January 13th, 2009, 09:16 PM
I'd first check your evaporator coils inside your freezer behind the back access panel, If the evaporator coils are all frosted up then turn your defrost timer clockwise to set it in the defrost cycle.
The defrost timer on your model is #17 here:
http://c.searspartsdirect.com/lis_pn...2007-00009.png
Behind the light shield that just pulls off.
Then that should make the defrost heater come on.
The defrost heater is #20 here:
http://c.searspartsdirect.com/lis_pn...2007-00001.png
The defrost thermostat is #30.
If the defrost doesn't come on, then thats possibly bad.
You will need a volt/ohm meter, you can get a cheap one at Radio Shack. I usually find the defrost heaters bad about 75% of the time, so I would ohm them first for continuity.
Make sure you unplug your refrigerator first.
Your defrost timer:
Manufacturer's Number: 68233-3
Your defrost thermostat:
Manufacturer's Number: 52085-29
Your defrost heater:
Manufacturer's Number: 61001846
Old January 19th, 2009, 08:51 AM
It was the defrost heater. It has been replaced and it all works perfectly. Thanks!!
*I ALMOST had him talked into a new fridge. Darn. LOL
Old January 19th, 2009, 09:33 AM
hahaa, maybe next time, if your compressor ever goes out, then you will be enjoying the fresh new smell of a new refrigerator.
Kenmore Coldspot not cooling on either side properly jehaywood Sears Kenmore 13 November 5th, 2007 09:30 AM
Admiral HMG62186 Fridge Not Cooling grose70 Maytag/Magic Chef/Admiral/Jenn-Air 4 October 28th, 2007 10:27 AM
Whirlpool Fridge/Freezer Not Cooling Properly andyman1970 Whirlpool 7 December 10th, 2006 08:12 PM
Maytag S/S refrigerator (MSD2756DEW) is not cooling properly: mamtech Maytag/Magic Chef/Admiral/Jenn-Air 1 August 17th, 2006 08:43 AM
Refrigerator not cooling properly delroy Refrigerators & Freezers 1 August 6th, 2006 09:28 PM
