January 20th, 2009, 04:20 PM
Maytag Quiet Series 300 won't run through wash
I have a Maytag Quiet Series 300, when i press start, normal cycle lights as well as heated dry, sanitize, and tough scrub. It fills with water and starts the cycle, display shows 2H. This last for about 1 or 2 min. The display will then show 9 all lights go out and the rinse cycle starts and it will run down until 2 shows in the display then shuts off. Can you help please.
Jay
Model#MDBH970AWS
Serial#16423805CE
Reason: Model and serial numbers
January 20th, 2009, 05:59 PM
Hi Jay,
Unfortunately, these Maytag models have had numerous issues with the control board and control panels going out. I've replaced many of them myself.
Its always best to replace both as they work together. Too many times I've been out to replace either one or the other, then a couple months later I'm back to replace the other, so from then on, I just started replacing them both at same time.
Manufacturer's Number: 99003160
Here's the control panel for your model:
Manufacturer's Number: 6-917732
6-917732
January 21st, 2009, 03:36 AM
Thanks for the advice. I'll get the parts ordered and replaced then check back in with you. Have a good day.
January 21st, 2009, 08:24 AM
Ok, sounds good.
By kcarbs in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: January 2nd, 2012, 05:15 PM
By ChrisS in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: November 7th, 2008, 12:01 PM
By keithp in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: April 3rd, 2008, 08:14 PM
By NY Mike in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: February 17th, 2008, 04:45 PM
By tgakk in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: October 17th, 2007, 10:05 PM
