Old January 22nd, 2009, 05:35 PM
John0306 is on a distinguished road
Default Tool for microwaves
I have heard of techs using some kind resetable fuse or something resetable when putting fuses in a microwave. When I put a fuse in a viking microwave and shut the door sometimes they blow because the switches are not contacted at the same time. What would a tech use instead of blowing 3 or 4 fuses for testing a unit.
Thanks John the appliance tech in virginia
Old January 22nd, 2009, 05:43 PM
TechnicianBrian's Avatar
Hey John,
I have a resettable push button circuit breaker mounted in a box and connected to a couple leads that end in alligator clips. When I find an open monitor fuse, I will snap on my CB to conduct my test and adjustments, then put in a fuse once I am sure everything is in working order. You can make your own and save some fuses.
TechnicianBrian
AllTechAppliance.com
Old January 22nd, 2009, 06:15 PM
Thanks but when you say circuit breaker are you talking a house breaker.
What you have sounds great
John
Old January 22nd, 2009, 06:48 PM
No it is a panel mount push to reset breaker like this one. Use it with some jumpers or put it in a box, whichever works best for you.
TechnicianBrian
Old January 23rd, 2009, 03:53 PM
Thanks Brian I went to Radio Shack to find the switch but they didnt have 1, so I got a 20 amp GFI plug and will use that until I get the switch in..
Thanks again
JOhn
By the way what state are you in?
load squeak metal to metal on MAV7257AWW Atlantis rick_maclean Maytag/Magic Chef/Admiral/Jenn-Air 4 September 26th, 2007 10:39 AM
UltraWash 665.15835793 Pump Centering Tool Echous Sears Kenmore 2 August 26th, 2006 08:21 AM
