Old January 24th, 2009, 05:55 PM
Senior Member
delroy is on a distinguished road
Default Machine Not Letting out water.
Maytag Washing Machine
Model # MAV6451AGW
What causes this machine not to let out water?
Where on the machine to correct the fault?
Old January 24th, 2009, 07:25 PM
Check the water pump, I see things get jammed or stuck in there and cause it not to drain.
Here's the water pump for your model:
Manufacturer's Number: 21002240
Old February 17th, 2009, 05:01 PM
Senior Member
Default re:shematic diagram
There is a rectangular box under the heading"open position".There are two sets of circles with a line drawn between each. What does this symbol represent and how does it work.
Old February 17th, 2009, 05:51 PM
If the line drawn touches both circles that means its a closed circuit(continuity), if the line drawn only is on the one circle and not on the other circle, then its a open circuit(no continuity).
Need some pro advice/suggestions; changing my water heater ajm786 Water Heaters 3 July 28th, 2008 02:02 PM
Help a buddha out, Jake! HayaBuddha Sears Kenmore 7 July 31st, 2007 11:23 PM
Washing Machine Water Level Switch delroy Maytag/Magic Chef/Admiral/Jenn-Air 1 April 2nd, 2006 05:46 AM
