Old January 31st, 2009, 10:46 AM
slovak57 is on a distinguished road
Default Maytag MSD2356AEB Door Fountain Problems
I have an issue with the door fountain on my Maytag. The refrigerator continues to make ice cubes without a problem but nothing works from the door...no water and no ice cube dispensing. None of the LEDs are lit unless the fountain actuator switch is activated...then the CRUSH LED lights up and the fountain light turns on. I have replaced both the control board and the switch board with no effect. One thing that I thought was strange was something I found on the six pin connector that comes from inside the door and leads to the entire fountain assembly. When I set my meter to measure resistance, there is a short (0 ohms) between the white and black pin on this connector. Is this normal? What could be the issue?
Old January 31st, 2009, 11:41 AM
No, that doesn't sound normal. Sounds like a dead short.
http://www.servicematters.com/maytag...s/16010154.pdf
You can print the pages that deal with the dispenser assembly.
Tags
fountain, maytag
LinkBack to this Thread: http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/14970-maytag-msd2356aeb-door-fountain-problems.html
Posted By For Type Date
Maytag/Magic Chef/Admiral/Jenn-Air - Page 3 - ApplianceBlog.com - Appliance Repair Forums This thread Refback September 7th, 2009 08:12 PM
Maytag Brake Problems szn9rg Maytag/Magic Chef/Admiral/Jenn-Air 13 February 4th, 2009 11:42 AM
Maytag #MFI2568AEB Water/ice PROBLEMS superbond Maytag/Magic Chef/Admiral/Jenn-Air 0 August 12th, 2008 02:24 PM
Maytag double oven heating problems Rox Maytag/Magic Chef/Admiral/Jenn-Air 5 October 25th, 2007 01:01 PM
Maytag electric range problems carlos schopenhauer Maytag/Magic Chef/Admiral/Jenn-Air 1 June 14th, 2007 06:31 PM
Maytag Legacy Washer MOD# sav515deww Cycle Problems Warthawg Maytag/Magic Chef/Admiral/Jenn-Air 12 June 14th, 2007 11:10 AM
