Old February 5th, 2009, 07:57 PM
UncommonDave is on a distinguished road
Default Jenn Air JCD2389GT- Freezer not cold enough & ice maker issues
This morning my wife informed me that the ice maker was not working. I noticed that the food was borderline frozen.
I pulled the ice maker out, took it apart and inspected everything. reinstalled and the motor cycles, water fills, still no dump.
I think the problem with the ice may be the thermostat not letting the ice machine cycle because it is not cold enough.
Any suggestions?
Dave
Old February 5th, 2009, 08:21 PM
Hi Dave,
If the ice maker can't get cold enough, it wont make ice, so since you said your food in the freezer was borderline frozen, that makes me think you have a cooling problem.
Take some food out of your freezer, then put your hand in the freezer and feel your back panel inside your freezer, do you feel frost build-up on it?
Old February 5th, 2009, 08:58 PM
I think you are correct. The back of the freezer does not have frost. I have unplugged the unit and will reconnect in the morning. If it is a cooling problem as we suspect, what should I be looking for?
Dave
Old February 5th, 2009, 10:44 PM
First frost build-up on that inside freezer back panel, better yet would be to take that inside freezer back panel off and look at your evaporator coils for frost build-up. Normal frost pattern is a thin layer on all the coils, not thick build-up.
In the morning pull your refrigerator out from the wall, then take off your lower back access panel#21 here:
And check your defrost pan#16 to see how much water is in it.
Then plug your refrigerator in, and make sure your compressor#1 and condenser fan#15 next to the compressor is turning.
Let us know.
Freezer flooded and now ice maker not working jharris Whirlpool 5 August 29th, 2008 09:27 AM
GE Performance Profile freezer leaking and frosting at ice maker outlet bbwlp GE/Hotpoint 3 September 22nd, 2005 06:09 AM
