Old February 18th, 2009, 06:40 PM
Pratt.Drew is on a distinguished road
Default Maytag gas dryer MDG4000BWW Slow to dry
I have a Maytag Neptune gas dryer MDG4000BWW and it takes a long time for the clothes to dry. I've observed the gas-on/gas-off cycle. The gas is on for 20-25 seconds and is off for 1 min. 20 seconds. This applies to all settings: Timed Dry, IntelliDry, etc. Is this on/off gas cycle normal or are sensors or coils bad?
Old February 18th, 2009, 08:48 PM
Before I recommend buying parts for it, I always want to make sure you don't have a vent restriction where your dryer vents to the outside of your house.
Pull your dryer away from the wall, then take the exhaust vent hose off, then dry a normal load to see if it fixes it, open some windows if you have the dryer inside your house to let the hot/warm air out.
If it still does the same thing with the exhaust vent off, then yes, you would need new gas coils.
Here's the gas coil kit for your model:
Gas valve solenoid coil kit, 2 and 3 wire, new style
Maytag MDG5500AWW Gas Dryer Sensor Dry doesn't work anzils Maytag/Magic Chef/Admiral/Jenn-Air 3 January 4th, 2009 09:40 PM
Slow gas on a Maytag MGR6775ADS Double oven... Y2KGTP Maytag/Magic Chef/Admiral/Jenn-Air 13 January 14th, 2008 10:56 AM
Maytag Dryer MDE4000AYW slow dry clemfam00 Maytag/Magic Chef/Admiral/Jenn-Air 3 October 18th, 2007 07:46 PM
How to replace to drum roller on maytag gas dryer? rlsmith Maytag/Magic Chef/Admiral/Jenn-Air 5 January 6th, 2007 02:29 PM
Maytag Gas Dryer MDG5500AWW Long drying times alans1 Maytag/Magic Chef/Admiral/Jenn-Air 3 November 13th, 2006 11:44 AM
