My Magic Chef is leaking water from the freezer (I think) into the the top compartment & it is overflowing to the bottom of the fridgge. I will attach pictures to show the problem. The red outline is where all the water collects and overflows from
I had to upload a larger pic to better show the problem
Hi John,
Sounds like your defrost drain hole/line is clogged up, not allowing the defrost drain water to run to your defrost pan under your refrigerator. You'll likely need to take all the food out of the freezer then take off your back panel inside your freezer, and get a hair dryer and defrost all the ice underneath your evaporator freezer coils, then run hot water down the drain hole, and it should flow down fast. Jake
john53147 (March 3rd, 2009) | ||
No, pull your refrigerator out from the wall, then take off that lower back access panel, and you should see the defrost pan behind the compressor.
I found it & it was bone dry I will do as said in first post...Thank you very much
Sounds good John. Good job.
| Need some pro advice/suggestions; changing my water heater | ajm786 | Water Heaters | 3 | July 28th, 2008 04:02 PM |
| magic chef fridge leaking water | tryingtofish | Maytag/Magic Chef/Admiral/Jenn-Air | 3 | June 22nd, 2007 03:21 AM |
| water on floor under Magic Chef | dtorbeck | Maytag/Magic Chef/Admiral/Jenn-Air | 5 | May 8th, 2007 12:45 PM |
| magic chef water problem | larry harding | Maytag/Magic Chef/Admiral/Jenn-Air | 1 | March 16th, 2007 10:43 AM |
| GE Profile water dispenser line leaking | dlynch | GE/Hotpoint | 4 | October 4th, 2006 09:17 PM |
