Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Maytag Water Dispenser Issue, vibrating
  1. #11
    jwalk is offline Member
    Mar 2011
    cincinanti
    Thanks a lot Jake. I'm pretty handy at putting things together/replacing things. The directions appear to be very straight forward. Is this something someone typically can get done by themselves or would you recommend calling in someone?
  2. #12
    What I usually say is if your mechanically inclined and have fixed other things around your house, then you should be able to do it.
  3. #13
    Mar 2011
    cincinanti
    Hey Jake,
    I got my part but am not sure how to disconnect the filter head from the water valve. In a different post you mentioned posting instuctions but I cannot find them
  4. #14
    Water Filter Assembly
    1. Remove filter cover opening cover and pulling rear left
    side of cover to the left to release cover from holding
    pin.
    2. Filter head can be released from holding bracket by
    opening tabs on left side filter head and pulling
    downward and to your left to release filter head.
    3. Tubing needs to be disconnected from water valves
    in the machine compartment. (see water valve
    removal)
    4. After tubing is loose from water valves pull the filter
    head and tubing out the front of unit.
    5. Reverse procedure to reassemble.
    NOTE: Make sure to note tubing end colors when
    reinstalling new head and tubing assembly.
  5. #15
    Mar 2011
    cincinanti
    Thanks Jake but I must be missing the link somehow. In your directions there is a part that says "(see water valve removal)". Am I supposed to be able to click on this? If so, it appears in regular text for me (I cannot click on it) and I do not see a link to water valve removal anywhere else on the post?
    Jay
  6. #16
    Mar 2011
    cincinanti
    Jake one addtional question. My brother was looking at the wate head filter and was concerned about pulling the filter through the styrofoam piece leading into the fridge. Should this be of concern? I don't see any mention of it in your instructions.
    Jay
  7. #17
    Here you go:
    Water Valve Removal
    1. Remove water valve cover plate on left side of
    machine compartment in the back of the refrigerator(Pull the refrigerator out from the wall first)
    2. Disconnect wiring from water valve, reference color of
    connector to correct solenoid.
    3. Disconnect water tubing from water valve, reference or
    mark tubing to ensure correct hookup upon
    reassemble.
    4. Remove hex screw attaching valve to water valve cover
    plate.
  8. #18
    jbpehr is offline Member
    May 2011
    Cary, NC
    Default another noisy maytag dispensing water slowly
    lol, you inverted the 5 & 6 in your model# you posted in your first post, hahaa thought I was going crazy.
    Then when you posted the photo of your model# tag, I still didn't see the inverted 5 & 6.
    Its MSD2650HEQ.
    Repair-man in this forum said it was the filter-head will need to be replaced:
    Manufacturer part number 67004106 is RepairClinic item number 1070340
    67004106
    I'm experiencing the same symptoms with my MAYTAG fridge. My model is MFI2568AEW. Its French door style with water and ice on the left door. Would the part mentioned above fit my model as well?
    Thx,
    Jay
  9. #19
    Hi Jay,
    No, your model uses this one here:
    Manufacturer's Number: 12956202
    Unfortunately I don't have the instructions to tell you how to do it on this model.
  10. #20
    SmithC00 is offline Member
    Nov 2011
    Norfolk, VA
    Jake - My Jenn Air is experiencing the exact same problems. Could you tell me which part I need for my specific model?
    Model # JSD2695KES
    Let me know if you need more information in order to answer. Thanks much! - Carter
  1. Maytag Side-by-Side Water Dispenser Issue
    By Worjd in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 5th, 2008, 09:01 AM
  2. Water Dispenser SDX26VL
    By jxp_app in forum Amana
    Last Post: February 8th, 2007, 09:49 AM
  3. Kenmore refrigerator water dispenser drips
    Last Post: February 6th, 2007, 07:57 PM
  4. New Maytag Fridge, water dispenser not working.
    By minskore in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 29th, 2006, 08:09 PM
  5. Water dispenser sometimes OK then stops
    By nowater in forum Refrigerators & Freezers
    Last Post: August 2nd, 2005, 09:14 AM
