March 4th, 2009, 04:50 PM
Maytag Water Dispenser Issue, vibrating
Hello! First post here.
I have a Maytag MSD2560HEQ side by side
When I try to dispense water from the door, a loud vibrating noise comes from the behind the fridge, near the top. Water flows fast initially, then trickles.
I have tried 2 brand new filters with no change. I have checked water pressure from the wall and it is like a fire hose. I also removed the hose coming out of the valve (the one that leads to the tank) and it still does it at that location.
It seems like something is causing it in the filter area, but I cant get that assembly apart.
Any ideas? Thanks in advance!
March 4th, 2009, 07:00 PM
Please double check your model#, that one you listed doesn't pull up as good.
Your water inlet valve in the back of your refrigerator where your water supply line hooks up to is bad, I can get you the part# once you post a good model#.
March 4th, 2009, 08:00 PM
I'm pretty sure I have that # right. Here is a picture for reference:
The model # may explain why its been so hard to find info on it.
March 4th, 2009, 10:33 PM
wow, your correct, I don't think I've run across a model thats correct that no one has information on, I even checked Maytag's site and nothing.
I'll ask around to see if we can find why this model isn't pulling up as good anywhere.
March 5th, 2009, 06:16 AM
Thats strange you cant find anything about it. Its a pretty basic model... 26 cubic ft, temperature dials inside the fridge, and buttons for ice, crushed ice, and water on the door. I can take more picture if needed.
I just tried by-passing that valve. I had water on from the wall, going through the filter, then exiting hose that normally goes to the valve in a bucket. That set up made the same noise. So maybe its not the valve?
Thanks for your help on this. I know its not an easy one.
March 5th, 2009, 09:26 AM
lol, you inverted the 5 & 6 in your model# you posted in your first post, hahaa thought I was going crazy.
Then when you posted the photo of your model# tag, I still didn't see the inverted 5 & 6.
Its MSD2650HEQ.
Repair-man in this forum said it was the filter-head will need to be replaced:
Manufacturer part number 67004106 is RepairClinic item number 1070340
67004106
March 5th, 2009, 07:26 PM
Thanks a ton for the help. Sorry about the model#... Glad you guys caught it.
March 5th, 2009, 10:44 PM
Glad to help.
March 28th, 2011, 09:57 AM
Maytag filter head
Hey Jake,
I'm having the same problem with my fridge. Would the same filter head part number apply for Maytag model MSD2655HEW?
March 28th, 2011, 11:53 AM
Yes, your model uses the exact same one.
October 18th, 2009, 07:35 PM
By Worjd in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: May 5th, 2008, 09:01 AM
By jxp_app in forum Amana
Last Post: February 8th, 2007, 09:49 AM
Last Post: February 6th, 2007, 07:57 PM
By minskore in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: October 29th, 2006, 08:09 PM
By nowater in forum Refrigerators & Freezers
Last Post: August 2nd, 2005, 09:14 AM
