Old March 6th, 2009, 08:18 PM
Tycraig is on a distinguished road
Default Neptune Mod #MAH4000AWQ
My washer makes a growling noise during agitation and spin cycles. What is the cause and fix and how difficult is the repair?
Old March 6th, 2009, 11:42 PM
It could be a number of things, see if you can pinpoint exactly were the growling sound is coming from, I've even seen a bad belt do this sound.
Pull your washer away from the wall, take the back panel off and run it, and see if the noise is coming from the belt.
Here's the belt for your washer in case you need to order it:
Manufacturer's Number: 12001788
12001788
Old March 7th, 2009, 12:24 PM
I took off the belt and ran the machine... Sound is coming from the motor. I assume I'll need to replace the motor? If so, how difficult is it? Will I be able to remove it from the back access panel or will I have to take the whole machine apart to get it out and put the new one on?
Old March 7th, 2009, 09:28 PM
Whats the serial# of your washer? This model has two different ones it uses depending on your serial#.
You have a 10 year warranty on that motor/motor conversion kit. These motors are about $120-$200.
Read post#1 here:
Do NOT pay for the Neptune Motor Conversion Kit 12002039
Its fairly easy to change the motor.
Here's the online repair manual for your model that will show you how:
www.applianceblog.com/manuals/MaytagNeptunenew.pdf
Its on pages 8-1 & 8-2 you can print those pages out.
Maytag Neptune 8700 repair issues & Maytag Rant. jazzman_q Maytag Brands Forum 14 May 19th, 2009 09:40 AM
Do NOT pay for the Neptune Motor Conversion Kit 12002039 cyber16 Maytag/Magic Chef/Admiral/Jenn-Air 2 January 17th, 2008 09:40 PM
Maytag Neptune drying times -- too long? TroyW Maytag/Magic Chef/Admiral/Jenn-Air 5 December 1st, 2007 02:39 PM
Help! Neptune MAH5500BWW ??? blessings4mom Maytag/Magic Chef/Admiral/Jenn-Air 1 September 3rd, 2007 09:36 AM
Maytag Neptune - No spin cycle fox_1028 Maytag Brands Forum 1 May 24th, 2006 09:15 AM
