Old April 3rd, 2009, 06:04 AM
njguy0414 is on a distinguished road
Default [FIXED] Admiral LNC6760B71
Hello,
(Admiral LNC6760B71 has a loud grinding sound)
I am new to this forum, and I was searching for help online and I found this place. I am renting out my condo, and my renters complained about the washer making a loud noise on the spin cycle. Trying to be a good landlord, I went over to see if there was anything I could do to fix it. I've only been a landlord for 8 months so this is all new to me
I opened up the front panel, and I looked underneath. I gave the belt a pull, and all 3 wheels could spin. The only odd noise I would hear while spinning manually, was the pump?? in the back. It sounded like a grinding. It's the clear plastic part that has hoses connected to it for draining. I took off the belt, and started it up. The motor spun fine with no noise.
But when it's all hooked up, something is making a loud grinding sound. The basket does start to spin up. But I smell something, I think it's from the motor.
Am I looking at a transmission issue, or is it the plastic pump thing in the back? I saw a sticker underneath that had 2003 on it, so I assume that's how old it is. I've come here since I can't really afford to buy a new washing machine, and wanted to save any money I could before calling in a repair person. I hope this is something I can fix....
I have pics if needed.
-Jason
Old April 3rd, 2009, 08:35 AM
Here's a help link to access the inner parts:
http://www.applianceaid.com/atlantis.html
I would first tilt your washer back then take the belt off your pulleys, then turn your water pump pulley first, to see if it makes the grinding sound, if so, then you found the problem.
When you turned the water pump pulley by hand did you feel it grinding? turning rough? It should turn smooth, no grinding at all.
Here's the water pump for your model, in case you need to order it:
Manufacturer's Number: 21002240
21002240
Old April 3rd, 2009, 09:29 AM
Hi Jake,
I did exactly that, took the belt off and turned each individually. When I turned the pump pulley, it did grind.
21002240
So if something was broken or stuck inside if this water pump, this would cause the motor to smell since its not spinning freely correct? I'm rally hoping it's just this!
By the way the part you linked doesn't have a picture on that site, but it looks like the part on this page here...
Old April 3rd, 2009, 10:21 AM
Yes, you can take the pump off and take the rubber hoses off of it and look inside it for foreign objects, if none, then its the pump bearing itself thats bad.
That pump I linked you to is the correct one for this model.
Part Number 35-6780 (AP4373022) replaces 21002240, 21001873, 21002219, 21002240, 21001873, 21002219.
Old April 3rd, 2009, 10:33 AM
ok - thanks. I'll report back after I get the part installed.
Old April 3rd, 2009, 11:05 AM
Ok, sounds good.
njguy0414 (April 8th, 2009)
Old April 8th, 2009, 04:59 AM
It worked!
I did notice that the older part had the round metal plate that sat in between the nylon casing and the pulley on the bottom. This seemed to be rubbing on each other. Guess that's why it was discontinued with that metal.
Thanks for the info. My tenants were very impressed that I fixed it. I'm very glad I joined up to this site!
Jason G.
Old April 8th, 2009, 08:21 AM
Excellent, good job fixing it Jason.
[FIXED] Admiral washer LNC6760B71 snubber rbrown1946 Maytag/Magic Chef/Admiral/Jenn-Air 3 December 2nd, 2008 08:17 PM
Admiral Washing Marchine, stops at fill, spins like a jet engine kelliinabq Maytag/Magic Chef/Admiral/Jenn-Air 2 May 29th, 2007 10:17 AM
admiral 520 Timer Wiring Diagram verycheeky Maytag/Magic Chef/Admiral/Jenn-Air 5 December 17th, 2006 12:24 AM
Admiral HMG 64163 drain issue? sfurukawa Maytag/Magic Chef/Admiral/Jenn-Air 7 October 20th, 2006 10:46 PM
Admiral LNC Tub bangs/bounces around lucid Maytag/Magic Chef/Admiral/Jenn-Air 9 October 31st, 2005 10:40 PM
