April 14th, 2009, 06:30 PM
LAT9734AAE Washer Shakes in Spin
LAT9734AAE Washer Shakes in Spin . The washer shakes only with a load,seems to be ok with an empty basket. Is there anything that would exagerate a slightly off balance load in the spin. Nothing seems to be loose. All four legs are snug,tight to floor and jam nuts are tight. Varying water level doesn't seem to change anything. Any suggestions?????
April 14th, 2009, 10:01 PM
Yes, it sounds like the damper is bad.
Here's the damper pad kit you can order:
Manufacturer part number 203956 is RepairClinic item number 1282
Here's a help link for the damper pads on Jeff's site:
http://www.applianceaid.com/may-wash-common.html#noise
April 15th, 2009, 03:36 AM
Would this also cause the washer to move around the floor?
April 15th, 2009, 05:02 AM
I agree with Jake .. have replaced many of these for this problem .
Tim
April 15th, 2009, 09:06 AM
Originally Posted by
murman92
Yes, it would.
By 2mbb in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: November 17th, 2008, 10:38 PM
By jasboods in forum Maytag/Magic Chef/Admiral/Jenn-Air
Last Post: October 1st, 2007, 11:41 PM
By sarora in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: August 5th, 2006, 08:41 AM
By a&p in forum Sears Kenmore
Last Post: January 23rd, 2006, 11:55 PM
By woz in forum Whirlpool/KitchenAid/Roper/Estate
Last Post: June 1st, 2005, 09:56 PM
