Old April 21st, 2009, 03:36 PM
Station40-71 is on a distinguished road
Default Mah3000aww
When I push the start switch the water starts to run for about 10-20 seconds and then everything shuts off. The lock light does not light. I have replaced the wax motor, checked R11 (and it appears intact), checked the Q next to it and it looks good (intact without evidence of burning up), and see no problems on the main circuit board.
Any other thoughts.
Thanks.
Old April 21st, 2009, 07:38 PM
Yes, even though you don't show signs of anything burning on your main control board, its still bad.
Order the main control board that applies to your serial#.
Part#12001725 Machine control board kit, MAH3000 prior to series 17. *Burned resistor on board indicates another problem within the machine
Part#22002988 Machine control board kit, MAH3000 series 17 & after. *Burned resistor on board indicates another problem within the machine
The series# is the first 2 digits in your serial#
Maytag Neptune MAH3000AWW laroc Maytag/Magic Chef/Admiral/Jenn-Air 9 December 14th, 2008 08:47 AM
Maytag MAH3000AWW giving me trouble again laroc Maytag/Magic Chef/Admiral/Jenn-Air 1 March 4th, 2007 10:51 PM
MAH3000AWW Won't High Speed Spin CWBR Maytag/Magic Chef/Admiral/Jenn-Air 3 December 20th, 2006 01:32 PM
mah3000aww - preventative maintenace crystal368 Maytag/Magic Chef/Admiral/Jenn-Air 1 October 9th, 2006 09:23 AM
Neptune Mah3000aww bearing size and where to buy? zhangji70 Maytag/Magic Chef/Admiral/Jenn-Air 1 December 28th, 2005 07:45 PM
