Old April 26th, 2009, 01:59 PM
farsidedawg is on a distinguished road
Question MAH3000AWW Problems
Good evening,
I have an issue with a Neptune MAH3000AWW we just purchased from someone. We plugged it up and started to run an empty wash with Clorox to clean it out. I heard the "jet sound" that some people have complained about in other posts, but it wasn't really that bad. What WAS bad was when it started sounding like it was going to break through the floor when it was spinning. It sounded like having an off-balance load in it, and then it'd stopped for a minute or so and then start back up. I stopped it and when I got the door open, there were plastic shavings (I can see where it's been taken from the outer edge of the opening plastic ring)!!! This was not like this when I checked it out before starting, so I'm wondering if we did something during transport. Help! What do we need to do?
Old April 26th, 2009, 08:57 PM
Hope you didn't pay much for this machine. Your rear bearing is bad, and its causing this issue.
Its quite possibly the bearing was already on its way out, and transporting it made it get this bad now.
Did you buy this from a private party or a used appliance shop?
Old April 27th, 2009, 05:13 PM
I bought it from a private party, but I only paid $200, so I'm not out much. My husband told me there's a "clicking sound" in it when the tub turns - it sounds like it's coming from below the tub, and it changes sounds slightly when the rotation changes. Would this also be part of that same problem or something else? How much would a rear bearing cost me, and could my husband install it? We do not have a repair manual, but if someone could give us instructions, we could probably handle it. Thanks for the info!
Old April 27th, 2009, 07:36 PM
Yes,
Mad Mac started a good post about the Maytag Bearings:
http://www.applianceblog.com/mainforums/showthread.php?t=1065
When I change them, I always order the complete outer tub assembly:
Outer tub, bearing & seal kit.
Its more expensive then just the bearings, but saves alot of labor.
Old May 2nd, 2009, 04:09 PM
Ouch! How much do just the bearings cost?
Old May 3rd, 2009, 07:57 AM
You would need to go to your local bearing shop in your area and see what they charge for it per this post:
http://www.applianceblog.com/mainfor...7&postcount=22
Old May 16th, 2009, 07:23 AM
We moved the washer again (figured we'd do that before we repair it), and when I opened the door, I found three bearings (about 3/8"). Does this mean there's more of a problem than just the bearings issue?
Old May 16th, 2009, 08:28 AM
Yes, possibly, three bearings were in the tub without you even taken it apart first, just from moving it?
Old May 16th, 2009, 10:51 AM
Sorry - my bad! Hubby pulled off the front panel, and the bearings were underneath the tub, not actually in it as I thought.
Old May 16th, 2009, 10:15 PM
Are you sure they are the bearings? lots of times installers leave the shipping rings that look like bearings in the machine after its delivered new.
Only way to find out for sure is to take the machine apart and see.
Tags
mah3000aww
[FIXED] Whirlpool Duet Washer F02 Problems HELP!!! Carroncaron Whirlpool/KitchenAid 28 December 8th, 2009 08:48 AM
Heater igniter problems WireDawg HVAC 1 April 13th, 2009 07:33 AM
Lots of Freezer problems all at once! chrissielsu Frigidaire/Electrolux 5 April 6th, 2007 08:29 AM
Magic Chef Microwave Problems Eagle Spirit Maytag/Magic Chef 3 December 18th, 2006 02:30 PM
HELP! Problems with Kenmore Dryer AMS Sears Kenmore 2 July 26th, 2006 04:10 PM
