I have a maytag MZD2766GEW. I think its about 4 years old. I got it already installed in a house that I bought last year.
Last summer, the refrigerator side stopped working, no cooling at all while freezer was working fine after I tried to set the temperatue from 6 to 8 in the fridge section. after a while i realized it had stopped working so we played arounf with the temperature dial for a while and then it started working. I had forgotten all that and 2 days ago I tried to set the temperature from 6 to 8 again and it stopped working. Freezer side is working fine. but no cooling in the fridge part. and tried moving the temparture dial pin to various numbers but it just does not start..... I looked on some threads here and tried to see if i have any ice frosen in any part of fridge or freezer but i dont see anything... where should i look next? what can cause this? any ideas? a repair guy was at my house to see my water heater and when I talked to him ahout this he said that he thinks we left the fridge door opened for sometimes (not shut properly) and this has caused frosting... and we should let it defrost, shut power and open doors and it should be fine once everything is melted... i am going to try taht but any other ideas are welcome! Thanks, Carpdiem Last edited by carpdiem; April 27th, 2009 at 11:52 AM.. Reason: adding some more... |
I would take the food out of the freezer and take the selves out and take off the lower back panel inside the freezer and check your evaporator coils to make sure they aren't all frosted up. Normal is just a thin layer of frost on ALL the coils. Maytag did have alot of issues with the Adaptive defrost control board, you may want to read this thread, it explains all about it: [FIXED] Maytag Refrigerator Model MSD2756DEB is not cooling properly Let me know what you find. Jake
Its located inside the top console inside your refrigerator section that mounts to the inside refrigerator ceiling, that console will drop down, then you can change it.
Here's the adaptive defrost control board for your model, you can order: Manufacturer part number 61005988 is RepairClinic item number 948430 61005988Here's the repair manual for your model: http://www.servicematters.com/maytag_library/docs/16010154.pdf Page 2-14 tells you how to replace it. Jake
| [FIXED] Maytag MAH3000AWW, ocassionally won't drain/spin | docmag | Maytag/Magic Chef/Admiral/Jenn-Air | 23 | March 6th, 2009 11:44 AM |
| Maytag is No More in Newton Iowa | Camster | General Appliance Chat | 6 | April 28th, 2008 10:07 AM |
| Maytag MZD2766GEW not cooling enough!!! | Kimari | Maytag/Magic Chef/Admiral/Jenn-Air | 19 | October 31st, 2006 12:27 AM |
| Maytag Wide By Side - Compressor dies after 11 months | pete_nc | Maytag/Magic Chef/Admiral/Jenn-Air | 4 | August 16th, 2005 10:24 AM |
