Old May 5th, 2009, 09:57 AM
narleycharlie is on a distinguished road
Default [FIXED] Maytag Neptune problem
Hi , I have a Neptune mo#MAH8700AWW . Washer started making a humming noise and would not drain . I removed a piece or a wicker basket from the pump and it started draining , that was a good thing . Only now it has a different sound , a buzzing and the letters LO are on the screen . The washer was purchased as a floor model with no owners manuel so I have no idea what the LO is . Can you help ?
Old May 5th, 2009, 10:50 AM
LO error code means Door Failed to Unlock after 3 attempts.
Can you open the door?
Try unplugging your washer for 5 minutes to see if it will reset.
Old May 6th, 2009, 10:07 AM
Well 2 hrs wasn t enuff to reset the computer , but overnite did the trick . As of now it is working , thanks for the help . charlie
Old May 6th, 2009, 10:23 AM
Excellent Charlie, glad its working good again.
Maytag Neptune 8700 repair issues & Maytag Rant. jazzman_q Maytag Brands Forum 14 May 19th, 2009 09:40 AM
Maytag 1502ARW problem Katiemay Maytag/Magic Chef/Admiral/Jenn-Air 11 August 30th, 2006 10:49 AM
Maytag Refuses To Solve Problem Mike B Maytag Brands Forum 2 July 13th, 2006 10:01 PM
Maytag Neptune 9700 mommaleaman Maytag/Magic Chef/Admiral/Jenn-Air 3 June 28th, 2006 09:06 PM
Maytag Neptune - No spin cycle fox_1028 Maytag Brands Forum 1 May 24th, 2006 09:15 AM
