Old May 6th, 2009, 08:00 PM
Lafngas is on a distinguished road
Default [FIXED] Water/Ice dispenser problem
Hello,
I have a Maytag MZD2766GEB wide by side refrigerator and the panel for the Ice/water dispenser is not lit or working. Only if I push the switch (where the cup pushes) will the led light for my selection and the night light will come on, but nothing happens. Is this a circuit board problem?
----Chris
Old May 7th, 2009, 12:36 AM
Hi Chris,
Yes, it sounds like your dispenser board is bad. I have replaced a few of these myself for this same issue.
Here's the dispenser control board for your model:
Manufacturer's Number: 61005274
61005274
Its #12 here:
The instructions to get access to it are here:
http://www.applianceaid.com/image/el...-dispensor.JPG
Old May 7th, 2009, 12:07 PM
Thumbs up
Alright, I will get one and let you know the outcome.
---Chris
Old May 7th, 2009, 04:21 PM
Sounds good Chris, don't worry, we have good return policy here, if you install it and it doesn't fix the problem, you can uninstall it and return it for a FULL refund within 30 days.
Lafngas (May 20th, 2009)
Old May 19th, 2009, 09:15 PM
Well, I have replaced the control board and the dispenser panel board and still have the same exact problem. Any other ideas???? By the way the Ice maker is still working.
----Chris
I really HATE this refrigerator!!!!!!!!!!!!!! Nothing but trouble since week 1.
Old May 19th, 2009, 11:29 PM
Sorry to hear it didn't fix it, not sure what else is causing it, unless you have a short in your wiring harness to the dispenser, check your connector, its usually located under the top freezer door hinge cover, or lower freezer door hinge cover.
Old May 20th, 2009, 09:24 AM
What should I look for as far as voltages for each of those wires? Also there is a tan wire between the control panel and the ice maker ---- what is it for??
And I thought this would be a simple fix...
Old May 20th, 2009, 12:23 PM
Here's the repair manual for your model#:
http://www.servicematters.com/maytag...s/16010154.pdf
3-8 and 3-10 explains what the voltage should be and diagnostic checks on it. You can print it out as well.
Not sure what that tan wire is for, the repair manual should say.
Lafngas (May 21st, 2009)
Old May 21st, 2009, 03:08 PM
Hello Jake,
Turns out it was the Fountain Heater, why they designed it so that malfunction causes complete failure of the Ice/Water Dispenser is beyond me The board looks for 4300 ohms in this unit. I am back in business. Thanks for you help. Where can I make a donation to this site?? It has been an asset to me.
-----Chris
Old May 21st, 2009, 05:45 PM
Good job Chris.
There is a Donate button at the very bottom of this page, thanks Chris.
AMANA water/Ice Dispenser not working. PANEL? mfjohnston Amana 5 June 14th, 2007 10:06 PM
Kenmore SxS 25357682790 Dispenser problem Gr8tgreg Sears Kenmore 2 April 12th, 2007 12:58 PM
no power to water/ice dispenser? n11 Frigidaire/Electrolux 3 November 20th, 2006 09:29 AM
Water Dispenser problem 106.50589001 Mannfamily Sears Kenmore 9 March 23rd, 2006 12:25 PM
frigidaire water/ice dispenser inop exwoodsplitter Frigidaire/Electrolux 1 January 16th, 2006 11:18 AM
