Model MAH3000AWW
Serial 37298851WD Machine was doing a load of wash. I came down to change loads and it was stopped in the middle of the cycle. I restarted it, and the machine does the following things ... Drum turns normal at wash speed, in both directions. The timer does not advance the "door locked" light does not come on, nor is the door locked. Does not fast spin When I manually advance the timer, I will get a 1 second spurt of water, then it stops. Is it the door lock wax motor? |
Looks like this is a 1999 model Neptune, have you had any work done on it at all since you've owned it? You will not only need the wax motor kit, but also the main control board. And if you haven't had the new motor conversion kit installed yet, you will likely need that as well. These Neptune's have had lots of recalls on them in the last 10 years. Here's the main control board for your model: Manufacturer's Number: 22002988 Here's the door latch wax motor for your model: Manufacturer's Number: 12002535 Jake
Replaced the door latch wax motor ... and that did not fix it, so onto the control board.
The R11 resistor is fried. Has anybody ever tried just replacing the resistor? I would like to try that first and spend one dollar before replacing the whole board. The question is how many ohm resistor is it? Anybody know? (that means you Jake ... ha ha) Thanks for your help !!! |
One more question ...
I looked up the control panel and you note ... "burned resistor on board indicates another problem in the machine" ... what does that mean? The only think I have done to the machine so far was replace the timer ... 3 weeks after it was brand new, and I did seals and bearings. |
Replaced the R 11 Resistor, and the Q6 triac, and the wax motor ...
Less than 20 dollars ... all is working good so far ... |
Excellent, lets cross our fingers to hope it lasts.
| Maytag Neptune 8700 repair issues & Maytag Rant. | jazzman_q | Maytag Brands Forum | 14 | May 19th, 2009 09:40 AM |
| Maytag Neptune Frnt load washer mold | unionflanker | Maytag/Magic Chef/Admiral/Jenn-Air | 1 | December 11th, 2008 07:28 PM |
| Maytag Neptune...should I buy it? | Klute | Maytag/Magic Chef/Admiral/Jenn-Air | 15 | December 28th, 2007 03:42 PM |
| Maytag Neptune 9700 | mommaleaman | Maytag/Magic Chef/Admiral/Jenn-Air | 3 | June 28th, 2006 09:06 PM |
| Maytag Neptune - No spin cycle | fox_1028 | Maytag Brands Forum | 1 | May 24th, 2006 09:15 AM |
