Old May 25th, 2009, 07:56 PM
Brook is on a distinguished road
Default Maytag not cooling
I have a Maytag MSD2756GEW that is not cooling the fridge, the freezer is fine. This has happened before and it was the damper thermostat unit, this doesn't appear to be the current problem. Before I fixed it, with the hep of this site, a service tech filled it with coolant to try to "fix" it. I believe it was over filled and now the line that comes out of the compressor ices over. It ices all the way from the compressor to where the line enters the freezer side. Will over filling cause this line to ice over? Will this cause the fridge side not to cool properly?
Brook
Old May 26th, 2009, 10:37 AM
Hi Brook,
Yes to both questions.
The service tech. will need to come back to remove the overfill.
Also did you take the lower back panel off inside your freezer and look at your evaporator coils to see if they were completely frosted up? Normal would be a thin layer of frost on all of them.
Old May 26th, 2009, 11:48 AM
No, I haven't looked at the evap coils. What should I expect givin the current issue? Will they be total iced over? I will take a look.
I also noticed that when I open the freezer door that the air flow from the freezer to the fridge increases. Should that be the case?
Brook
Old May 26th, 2009, 08:41 PM
Ok Brook,
Here's what it should look like:
Pic from Appliance411
Old May 29th, 2009, 03:27 PM
I looked at the evap coil and it looked normal. I checked on it throughout the day and the frost did get a bit heavier, looking like the third picture, but never excessive. I also observed a defrost cycle and the coils became perfecty free of frost. The refridge side seems to working fine now but I'm thinking the problem will reoccure until the proper coolant charge is in the compressor. I called a service repair place and got a quote of 175-200$ to take out the coolant and put new in. Is that resonable?
Thanks.
Brook
Old May 29th, 2009, 03:43 PM
NO, not at all, all the tech. has to do is recover the excess amount in a recovery bag, and use his manifold gauges to get the low side down to about 3 on the guage.
He doesn't need to completely take it all out and recharge it.
Maytag # MBF2556KEB not cooling . . is it fan or defrost control??? miketucker52 Maytag/Magic Chef/Admiral/Jenn-Air 5 October 5th, 2008 08:59 PM
Maytag Fridg Not Cooling Quill Maytag/Magic Chef/Admiral/Jenn-Air 5 October 4th, 2007 12:43 PM
Maytag PTB195LGRW not cooling rocksguy Maytag/Magic Chef/Admiral/Jenn-Air 2 August 9th, 2006 11:36 AM
Maytag MSD2456GE Quit Cooling then... Alf50990 Maytag/Magic Chef/Admiral/Jenn-Air 11 March 27th, 2006 12:39 AM
