Old May 26th, 2009, 01:17 PM
Aaron Berk is on a distinguished road
Default Atlantis MAV6260AWW with video
Awesome forum here, wish I had come upon it sooner. $5 is but a small price to pay!
So here is my issue,
I was getting random loads in my washer that were sopping wet. It was a spastic thing, most of the time my clothes came out damp like there supposed to. Well it's gotten worse and started making a noises on the final 2 cycles and I needed to do something about it. The washer is 6 yrs old and I've got 5 kids so it gets lots of use. When I looked under the washer there was evidence of belt wear, lots of black powdery junk on the 3 pulleys. So I changed out the belt and crossed my fingers.
Bought the belt from the link on this site by the way
Now I'm getting a louder noise and I'm on my 1st load with the new belt, I took a video of whats going on. The load still hasn't finished, I came here and paid the 5 bucks right away cause I think I might be over my head on this one. Here is the video link http://www.youtube.com/watch?v=_DGUicLfxF8
Any help would be great.
Thanks Aaron
Old May 26th, 2009, 02:02 PM
Default Load 1 was a success!
Ok with the exception of the afore mentioned noise, the load went through with out a hitch.
Hmmm... I'm thinking I'll keep washing. Laundry has piled to high to let a little noise slow me down now.
Still need to get it up 100% though
Old May 26th, 2009, 08:01 PM
Hi Aaron,
I would first tilt your washer back then take the belt off your pulleys, then turn your water pump pulley first, to see if it makes the grinding sound, if so, then you found the problem.
When you turned the water pump pulley by hand did you feel it grinding? turning rough? It should turn smooth, no grinding at all.
Here's the water pump for your model, in case you need to order it:
Manufacturer's Number: 21002240
21002240
If thats ok, then turn your motor pulley and see if that grinds.
Here's the motor for your model you can order:
Manufacturer's Number: 21001950
21001950
If both check ok, then its likely your transmission assembly, it would cost more to fix than its worth.
Old May 26th, 2009, 08:14 PM
Thumbs up Thanks Jake
I was leaning towards the Transmission as the fault, I've got a doctors style stethoscope that I use for automotive work and I used it on the washer. The sound does appear to be coming from the transmission. I don't feel like climbing under the washer again tonight so I'll remove the belt and check what your suggested in the AM.
Should they all spin freely by hand?
And do you know what puts tension on the belt?
Aaron
Old May 26th, 2009, 08:27 PM
The pivot spring puts tension on the motor mount clutch, so when the motor reverses for the spin & drain cycle, its turns the water pump pulley fast enough for a steady 60-90 sec. drain.
I have seen that motor pivot spring plate get dirty and dry and cause that pivot plate not to make a smooth pivot transaction when the motor reverses.
Try to lubricate that motor pivot plate when a compound like Sil-glyde lubricant, you can order or get at any appliance parts store in your area.
Old May 26th, 2009, 08:42 PM
Default Tossed in another load
I've got a big load of towels in now, my 2nd load since the new belt. She's not putting up a fuss this time, running quiet just like it used to. Hmmm..... I don't like intermittent problems they usually cost more. I've got a home warranty that for $50 will come fix or replace the washer, if I get more noises out of the transmission I'm making the phone call.
Old May 26th, 2009, 11:25 PM
Ok, sounds good Aaron,
Keep us posted on what happens.
Old July 17th, 2009, 07:23 PM
Default Transmission is shot
Well there goes the washer.
So whats the best make and model out there by the way?
If money was no option...
What should I replace it with?
We're looking for a 5cu ft capacity or more.
Old July 18th, 2009, 09:56 AM
Sorry to hear the transmission is shot.
Whirlpool Duet & Maytag Performance are very good front-load washers, but highest capacity I found for these was 4.4cu ft.
You can search here by clicking this banner:
Aaron Berk (July 18th, 2009)
Old July 18th, 2009, 06:39 PM
Default Thanks Jake
Would you recommend those same brands in the high efficiency top load models as well?
The repair guy from my home warranty told me to stay away from the new Maytag lines, and go with a Whirlpool because Whirlpool is now the parent company of Maytag. Also steer clear of the LG brand, but the local sales man said LG is awesome, just no one knows how to fix/work on them so thats why they get the bad rap.
My better half is really pushing to get the best of the best. We have a Whirlpool Cabrio top load HE on loan right now, she's been reading reviews about it all day and says it "ties the clothes together"
We're leaning towards a top load because the capacity is higher than the front loads.
So um...... maybe some more pointers or recommendations?
Maytag Atlantis Dryer Questions scottdfuller Maytag/Magic Chef/Admiral/Jenn-Air 7 April 27th, 2009 04:43 PM
Maytag Atlantis model # mav6200aww timely1 Maytag/Magic Chef/Admiral/Jenn-Air 2 February 3rd, 2008 08:18 AM
Maytag Atlantis MAV9600 squealing dashrat Maytag/Magic Chef/Admiral/Jenn-Air 7 October 11th, 2006 08:25 AM
Maytag Atlantis not draining in Rinse/Spin Cycle - SOMETIMES JimsWasher Maytag/Magic Chef/Admiral/Jenn-Air 3 August 22nd, 2006 11:44 AM
Maytag Atlantis KEEPS draining/filling for rinse.... stile Maytag/Magic Chef/Admiral/Jenn-Air 1 July 17th, 2006 07:47 AM
