Hello,
I have an Admiral washer model #LNC6762B71 that will not spin in any cycle. We had an article of clothing get under the agitator and got stuck. I had to remove the agitator to free the piece of clothing. I re-assembled the washer and proceeded to see if the machine would complete a cycle.
I tipped the washer up and the belt is intact no frayed edges and the motor turns.The tub will not turn manually at all. Any help or suggestions would be greatly appreciated. Last edited by ekoncepts; June 12th, 2009 at 09:42 PM.. Reason: Gave wrong model information in title |
Ok, tilt your washer back and take the belt off, then turn your transmission pulley both ways, one way will make it agitate, the other way should make the tub turn, if the tub doesn't turn then the thrust bearing is bad.
Thrust Bearing Kit(Comes with complete installation instructions) Part#12002213 When I worked for Montgomery Wards, I must of replaced at least 1 one these every week on their washers which were made by Admiral(Division of Maytag) Jake
Thanks for the reply. I did as you instructed, but would like to confirm what is happening is what is supposed to be happening. Note: while waiting for your reply I have torn down the agitator and removed the tub to check for any obstructions. (none found) Replaced the tub, but not the agitator for your test.
The tub would not turn no matter which direction I turned the pulley. Question:
Am I over thinking the problem? Just trying to eliminate any other possibilities before buying any parts. Because if it's a motor issue I will probably consider replacing this machine. If is does turn out to be the Thrust Bearing that needs replacing the repair shop said there are 2 different series for that machine. But the schematic I found online for the machine does show a Series 17 & 22, but both diagrams have the same part # and description for the Thrust bearing. But they said the parts were different. How do I determine which one I need? Model # LNC6762B71 Serial # 20476957CR Rev: 20 Thanks, Harry Last edited by ekoncepts; June 13th, 2009 at 08:56 AM.. Reason: added more information about the machine |
Ok, it sounds like your transmission is bad, because you said when you turned the transmission pulley one way the agitator shaft moved back and forth, and then you turned the transmission pulley the other way, and it did the same. But it shouldn't have done the same, it should have started to rotate the tub and not the agitator. Did you keep turning the transmission pulley awhile to see if the tub would start rotating? Jake
If it is indeed the transmission, is it repairable or am I asking for more headaches down the road? |
I also have another question you might be able to help with. If I decide to replace the washer my wife has been asking about a machine that can accommodate a smaller auxiliary tub that could slip over the agitator. I remember years ago my Mom had one of these. They were great for smaller loads or delicate wash. Any idea if anybody still makes washers that have this feature? |
The transmission is replaceable, not repairable, but it would cost alot to replace, almost the cost of a new washer.
Those were the old GE models that you could put a smaller basket on the agitator, but they no longer make those. Whirlpool, Kenmore by Whirlpool are good washers. ![]() Jake
ekoncepts (June 14th, 2009) | ||
Jake, |
Yes Harry, it would be better to just save the repair money for a new washer.
| [FIXED] LHW0050PQ Washer won't Spin | 2mbb | Whirlpool/KitchenAid | 5 | November 17th, 2008 09:38 PM |
| Help! Washer shaking during spin cycle | jasboods | Maytag/Magic Chef/Admiral/Jenn-Air | 4 | October 1st, 2007 10:41 PM |
| Admiral Washer | sthrush | Maytag/Magic Chef/Admiral/Jenn-Air | 1 | September 5th, 2006 04:48 PM |
| Old Admiral washer won't spin under load | explorer22 | Whirlpool/KitchenAid | 5 | March 24th, 2006 10:12 AM |
| Kenmore Washer will not spin all the time | a&p | Sears Kenmore | 5 | January 23rd, 2006 10:55 PM |
