Old June 22nd, 2009, 08:03 AM
u118224 is on a distinguished road
Default Neptune Stack Softener Dispenser
Model MHW2000AWW. The softener dispenser is always full of water when the wash cycle is complete. It dispenses the softener, it just leaves clear water. I removed the plastic dispenser, fill it with water from the sink and it siphons just fine.
I have the repair manual but I couldn't find any info on this condition. I wonder if there's a soft obstruction in the lower dispenser/tubing that allows the liquid to pass through when water enters the dispenser, but prevents the dispenser from siphoning. I'll check that tonight, but, in the meantime, does anyone have any thoughts?
Old June 22nd, 2009, 09:06 AM
Have you just noticed this problem? There used to be no water in it before?
Have you cleaned it per the owners manual here:
http://shared.whirlpoolcorp.com/asse...MHW2000AWW.pdf
On page 8.
Old June 22nd, 2009, 09:30 AM
It was more intermittent prior to replacing the motor and motor control board, but it did do it; so, it's not a recent problem.
Thanks for the owner's manual, I can't find mine. I already had cleaned the removeable dispenser parts, as the manual instructs, as there was softener buildup in the dispenser compartment. That's why I thought some of the buildup may have partially clogged the tube that dispenses into the tub.
Regards,
Larry
Old June 22nd, 2009, 10:58 AM
Most Neptune models I've seen has a little bit of water left in it, but shouldn't be full.
Kenmore 80 fabric softener dispenser broken onlydarksets Sears Kenmore 10 October 9th, 2008 10:16 AM
HE3T - fabric softener dispenser not working Gary2007 Sears Kenmore 2 September 17th, 2007 08:24 AM
Help! Maytag neptune not dispensing bleach or softener dbfarris Maytag/Magic Chef/Admiral/Jenn-Air 11 July 9th, 2007 11:26 AM
How to unclog the liquid fabric softener dispenser? deckeda Whirlpool/KitchenAid 5 February 6th, 2007 08:43 PM
kenmore 70 series fabric softener dispenser seems clogged BillG Sears Kenmore 7 January 16th, 2006 10:43 PM
