Old June 28th, 2009, 12:02 PM
Frogh is on a distinguished road
Default Squeaking Maytag
Maytag Dependable Care, Quiet Pack, Heavy Duty, Auto Control Dryer
Model LDE9306ACE
S/N 10643575QW
So recently my dryer started to squeak a bit when I start it. The problem is not bad yet. In fact it is intermittent at the moment. The squeaks are short and only last about 10 secs when I do hear them. Also, sometimes when I start it, it kind of rumbles for a second when it starts. (again intermittent)
So there it is. If I have not given you enough info please let me know.
Old June 28th, 2009, 03:22 PM
The squeaking is either the idler pulley, belt, or rollers.
Here's the dryer drum roller for your model:
Manufacturer's Number: 12001541
12001541
Here's the belt for your model:
Manufacturer's Number: Y312959
Y312959
Here's the Idler pulley for your model:
Manufacturer's Number: Y303705
Y303705
Here's the repair manual for it you can print out the pages that explain how to change the rollers, belt, and idler pulley:
http://www.servicematters.com/maytag_library/docs/16000416.pdf
Jeff has a good link that shows you how to take it apart to check the blower wheel:
http://www.applianceaid.com/may-apart.html#common
The rumbling may be the blower wheel starting to strip out from the motor shaft.
Here's the blower wheel for this model:
Manufacturer part number Y303836 is RepairClinic item number 1245880
Frogh (June 28th, 2009)
Maytag Performa dryer squeaking neustkg Maytag/Magic Chef/Admiral/Jenn-Air 1 December 4th, 2008 09:55 PM
Maytag Epic 9700 squeaking? bobl Maytag/Magic Chef/Admiral/Jenn-Air 11 September 8th, 2008 09:24 PM
Maytag is No More in Newton Iowa Camster General Appliance Chat 6 April 28th, 2008 09:07 AM
Maytag Model DE612 Squeaking etrcdr Maytag/Magic Chef/Admiral/Jenn-Air 7 September 23rd, 2007 10:05 PM
Maytag Atlantis Model MAV6200AWW squeaking npershad Maytag/Magic Chef/Admiral/Jenn-Air 1 December 13th, 2005 11:09 AM
