Old July 6th, 2009, 05:55 PM
gr8filed is on a distinguished road
Default Maytag Performa won't dry on first cycle
Hello everyone and thanks in advance for your help. I have read a few posts that have the same symptom but not exactly. i have a maytag performa electric dryer model number mde3500ayw and serial number 40411503ac. The clothes will not dry on the first cycle. i did pull the unit away from the wall and checked for any blockage in the vent pipe but found none. I ran it with the hose off and found plenty of heat out the back. My wife said that she ran it today for a few minutes, felt good heat so she let it go. After the cycle was done the clothes were damp. She felt like the clothes were warm but not hot. Maby the heating element is kicking out mid cycle. It doesnt matter which type of drying cycle she choses, it always seems to take 2 cycles to dry. I dont think i am losing a leg of the 220 volt because why does it always work the second time? Are these units prone to have heating element failures? I am a automotive tech so i have the ability to take thinks apart and test them given some direction. I also tried cleaning those 2 chrome bars inside the dryer but that did not help. Please Help !!! Thanks again.
Old July 6th, 2009, 06:27 PM
http://www.servicematters.com/maytag...s/16023086.pdf
I'd take the front panel off(Page 5-1) and watch your heating element to see if it stays red for a long time or not.
Also if you can get a thermometer and take the temperature of your dryer from the back where the air comes out and tell me what it reads, normal heating cycle should be 120F-180F.
Does it do this on auto-dry or timed dry? or both? Normal timed dry should take 60 minutes to dry for a normal load of towels, jeans, etc.
Old July 7th, 2009, 03:25 AM
Default thanks
i will take the panel off tonight and ask my wife o watch the heating element as she does the wash. the dryer does not dry on any setting, auto or timed on the first run. is a heating element a common failure?
Old July 7th, 2009, 09:10 AM
Yes, the heating element can just burn out after 8-10 years of use on any dryer.
Since your dryer is about 10 years old now, you may be getting other parts wearing out as well, hate to see you dump a lot of money into this dryer, when new dryers really haven't gone up in price since 10 years ago.
Old July 7th, 2009, 04:52 PM
Default info
i know it is almost 10 YEARS OLD BUT IF IT A SIMPLE FIX I WOULD LIKE TO TRY. I HAVE THE FRONT COVER OFF AND CAN SEE THE ELEMent. it looks like there are several coils, some glow red all the way from front too back and some seem like they do not. i ran it and am getting 160 at the moment. i will have her watch the element tomorrow and see if it kicks out. thanks
eddie
Old July 7th, 2009, 07:46 PM
Ok eddie, sounds good.
Old July 12th, 2009, 02:33 PM
hey jake, i finally got around to looking at this dryer. I just put a load of clothes in. after about a minute the the heating element started to glow red. i put a thermometer in the back where the exhaust hose comes out and it only read about 80 deg. i let it run alittle longer and it never went over 100 deg. it looks like all the coils are not glowing red there entire length. should all the coils glow red from end to end? if they dont does that mean the element is bad? is there something elese i should be looking for?
thanks
eddie
Old July 12th, 2009, 03:18 PM
jake,
just alittle more info. i removed the heating element, found 11.1 ohms. on the heater housing, i think its the thermostat, 2 wires, 1 connected to heater elemnt, had .8 ohms. the other part on the housing, i think it was the fuse, also had .8 ohms. thanks,
eddie
Old July 12th, 2009, 08:59 PM
Ok, no, not all the element coils may glow red, but most should.
The readings you took for the element and thermostats are fine.
Did the heating element stay on for a long time when you first started it? how long?
Old July 13th, 2009, 03:22 AM
the element stayed on the whole time.
Whirlpool dryer LER 7646 AN1 stops in middle of dry auto cycle imidazol97 Whirlpool/KitchenAid 1 January 31st, 2008 11:07 AM
Maytag Performa only randomly starts with noise... jaegerd Maytag/Magic Chef/Admiral/Jenn-Air 3 May 10th, 2007 09:11 AM
Maytag sav4655ewq, loud jet engine sound in spin cycle problems Maytag Brands Forum 2 February 15th, 2007 09:11 PM
Maytag Neptune - No spin cycle fox_1028 Maytag Brands Forum 1 May 24th, 2006 10:15 AM
Maytag Performa won't drain on delicate cycle paid2fish Maytag/Magic Chef/Admiral/Jenn-Air 1 February 8th, 2006 11:26 PM
