Old July 19th, 2009, 08:59 AM
cblrpr1 is on a distinguished road
Unhappy maytag mah8770a
I have a maytag 8700a that keeps showing "nd" on my control panel. In the repair manual it says this is a draining issue but i've checked the hoses( no obstructions) and the pump seems to be operating correctly. Is there anything i am missing???
Old July 19th, 2009, 09:14 AM
Can't locate any information on that model# you posted, please double check it, closest match I found for it is MAH8700AWW
Old July 19th, 2009, 01:01 PM
Sorry, It's the 8700aww
Old July 19th, 2009, 03:43 PM
Did you physically take the water pump out and look inside it, lots of times I'll find something that got through to it and broke the impeller blades in it.
Here's the water pump for your model:
Manufacturer's Number: 34001320
34001320
Let me know what you find.
Old July 19th, 2009, 04:34 PM
took the pump apart and everthing seems to be functioning the way it should. Could this be a sensor problem. The pump operates correctly and both hoses are not clogged. I believe there are only 2 hoses one goes into the pump and the other goes out.
Old July 19th, 2009, 05:06 PM
Yes, could be the Water sensor or Sump sensor, he's the tech. data sheet on your model that tells how to test those:
http://www.servicematters.com/maytag...s/16026882.pdf
cblrpr1 (July 19th, 2009)
Old July 19th, 2009, 06:00 PM
Thank you, i'll give this a try!!
Old July 19th, 2009, 09:38 PM
Ok, sounds good, let us know how it goes.
Old July 21st, 2009, 08:24 PM
how do you get access to the control board, do you have to take the whole front off??
Old July 21st, 2009, 10:46 PM
I haven't taken this one apart as of yet, but it looks like you take the top off first then you can get access to it, read page #29 here:
http://www.servicematters.com/maytag...s/16026126.pdf
maytag mah8770a cblrpr1 Maytag Brands Forum 0 July 19th, 2009 08:53 AM
Maytag Neptune 8700 repair issues & Maytag Rant. jazzman_q Maytag Brands Forum 14 May 19th, 2009 09:40 AM
[FIXED] Maytag MAH3000AWW, ocassionally won't drain/spin docmag Maytag/Magic Chef/Admiral/Jenn-Air 23 March 6th, 2009 09:44 AM
Maytag is No More in Newton Iowa Camster General Appliance Chat 6 April 28th, 2008 08:07 AM
Maytag Wide By Side - Compressor dies after 11 months pete_nc Maytag/Magic Chef/Admiral/Jenn-Air 4 August 16th, 2005 08:24 AM
