Greetings:
My problem is slightly different than what we've read from other posters issues in this fine forum: If you hold the washers start button down at start of wash, it will only fill for about 5 seconds, then it goes dead, nothing. It will drain if ya keep holding the start button down, but the "on" light goes off. My serial number: 352 702 57WB Neptune front load MAH 3000 AWW Purchased new about 1999 / 2000. What do you recommend, and as long as I have the beast apart, what else should I do? Thank you for your time, takes, tips and tales. |
Ok, Motherboard, motor conversion kit, door latch assembly.
http://www.servicematters.com/maytag_library/docs/16010061.pdf The main control board is likely causing this problem, as Maytag had many problems with the early Neptune's doing this. Here's the main control board for your model: Manufacturer's Number: 22002988 Whenever you change the main control board you also have to change the door wax motor as well. Here's the door latch wax motor for your model: Manufacturer's Number: 12002535 Jake
Trailer Park Casanova (July 26th, 2009) | ||
Thank you sooo much.
Oh brother is your advise ever appreciated. - Ross and Ali |
Yes Ross and Ali,
I hate for you all to spend a lot on your Neptune with the age of it and all the issues its had. ![]() Jake
Thanks Jake. The delivery truck was full of dead Neptune haul-offs. Appreciate the honest and frank help. R&A. |
Thanks R&A,
Thanks for your help also in our HVAC Forum. ![]() Jake
| Maytag Neptune MAH3000AWW | laroc | Maytag/Magic Chef/Admiral/Jenn-Air | 9 | December 14th, 2008 08:47 AM |
| Maytag Neptune MAH3000AWW | smit1260 | Maytag/Magic Chef/Admiral/Jenn-Air | 3 | April 15th, 2008 10:02 AM |
| Maytag Neptune MAH3000AWW Sounds like a jet when spinning | dennisal | Maytag/Magic Chef/Admiral/Jenn-Air | 4 | July 12th, 2007 05:02 PM |
| Maytag Neptune Control Board Issue | tim205 | Maytag/Magic Chef/Admiral/Jenn-Air | 1 | January 17th, 2007 09:46 PM |
| Neptune Mah3000aww bearing size and where to buy? | zhangji70 | Maytag/Magic Chef/Admiral/Jenn-Air | 1 | December 28th, 2005 07:45 PM |
