Old August 4th, 2009, 12:36 PM
rcorwin is on a distinguished road
Question Maytag MBB2254GES not cooling, buzzing from relay on compressor
Hi all,
I have a 6 yr old Maytag refrigerator with the freezer on the bottom which has stopped cooling.
It started intermittingly for a few hours at a time and now it's not cooling at all, neither the refrigerator nor the freezer.
When I plug it in I hear buzzing from the relay attached to the compressor. (I took off the rear access cover)
The buzzing will start then click off, a few minutes later it will do it again, than again.
Could the compressor be shot or maybe just the relay?
Robert
Old August 4th, 2009, 05:15 PM
Hi Robert,
On these models I find that when it does this is more likely to be your compressor thats bad rather than the start relay, I always ohm the start relay(refrigerator unplugged) for continuity just to make sure. If you get 0-1 ohms on the start relay, then its fine and its the compressor for sure.
If your compressor is bad, you have a 5 yr. parts & labor warranty on it, but its already run out if yours is 6 yrs. old now. So it would be time to go refrigerator shopping, as to have a compressor installed is about $600.
Here's the start relay for your model, just in case its bad:
Manufacturer part#12555902 is RepairClinic item#821744
If it doesn't fix the problem, they give you 30 days to return it for a full refund.
Tags
bottom freezer, maytag, mbb2254ges
NEED HELP: Maytag model MSD2732GR not cooling mdn3914 Maytag/Magic Chef/Admiral/Jenn-Air 5 July 3rd, 2008 09:47 PM
Maytag PTB1954GRQ relay buzzing problem? Garye55 Maytag/Magic Chef/Admiral/Jenn-Air 5 August 4th, 2007 12:14 PM
Maytag MTB1753AR Compressor on but no cooling cougarcat Maytag/Magic Chef/Admiral/Jenn-Air 1 August 31st, 2006 12:46 PM
Maytag - clicking from compressor, no cooling ajne429 Maytag/Magic Chef/Admiral/Jenn-Air 4 July 11th, 2006 07:39 AM
Maytag MSD 2556 compressor clicking and not cooling uffdah Maytag/Magic Chef/Admiral/Jenn-Air 3 December 5th, 2005 11:58 PM
