MZD2766GE wide by side (2003). freezer side getting warm. fridge side ok. any idea what part i need and how to replace?
thank you wsk |
I'd first take the food out of the freezer and check your lower back panel inside the freezer and see if you have any frost build-up on it, better yet is to remove that lower back panel of from inside your freezer and look at your evaporator coils to see, Normal would be a thin layer of frost on all the coils. Also make sure your evaporator(freezer) fan is running, and pull your refrigerator out from the wall, then take off the lower back access panel and see if your condenser fan is running, it sits next to your compressor, and put your hand on the compressor to make sure thats running. Maytag has had a big issue with the Adaptive defrost board on these models. This thread explains all about it: [FIXED] Maytag Refrigerator Model MSD2756DEB is not cooling properly Here's the Adaptive defrost board for your model: Adaptive Defrost Control Board Part#61005988 61005988Jake
Thanks Jake! Works great. Glad I found the site.
Excellent wsk, good job.
jake: was working just fine. checked on it and now it is warming up. started with warm yn freezer and then went to fridge. same thing again?
What exactly did you do? Just change the Adaptive defrost board?
You also have to defrost the evaporator coil completely to get it to run normally after you installed it. ![]() Jake
Jake: I let the fridge sit off for 24 hrs. Until I recieved the part. I looked at the evaporator coil and it was dry.
It was dry? was the refrigerator running at the time or off?
Jake: fridge was off. i turned it off inside the fridge.
Ok, let it run now with the evaporator cover on, and we will go from here.
| Maytag Side by Wide MZD2766GE not cooling but... | bartockbat | Maytag/Magic Chef/Admiral/Jenn-Air | 5 | October 22nd, 2007 11:27 AM |
| Maytag MZD2665hew Wide by Side clicking and buzzing | emtkyle | Maytag/Magic Chef/Admiral/Jenn-Air | 4 | October 7th, 2007 12:14 PM |
| Maytag Wide by Side Crisper Temperature Problem | Traveler62 | Maytag/Magic Chef/Admiral/Jenn-Air | 6 | July 31st, 2007 12:59 AM |
| Maytag Wide by Side 5 years old and not cooling | tuggers | Maytag/Magic Chef/Admiral/Jenn-Air | 3 | June 26th, 2006 11:36 AM |
| Maytag Wide By Side - Compressor dies after 11 months | pete_nc | Maytag/Magic Chef/Admiral/Jenn-Air | 4 | August 16th, 2005 10:24 AM |
