August 29th, 2009, 11:17 AM
Oven slow to heat
I have a Maytag oven model # MGR5770BDW. It takes forever to heat to temp. The broiler and range works great. I checked the temp sensor and it is showing 1068 ohms. I checked the igniters and the bake igniter is the same color as the broiler igniter. There seems to NOT be the same volume of gas going to the bake element as the broil. The bake flame seems to be of less volume than the broil.
Any ideas?
August 29th, 2009, 11:36 AM
Ok, on your model you bake igniter is also used for broil, because you have the broiler drawer underneath your oven.
9 times out 10 its the oven glow bar igniter that causes this issue.
Here's the oven glow bar igniter for your model you can order:
Manufacturer's Number: 74007498
74007498
Just remove the bottom panel from inside your oven, then undo the wing nut#17 and take off your burner baffle#7 here:
Then remove the screws holding your oven igniter#14 and disconnect it from the plastic connector plug at the end, you will have to remove your broiler drawer to unsnap it from underneath.
Unplug your range first before servicing!
August 29th, 2009, 11:52 AM
Thanks. I ordered the part from the link you provided andd will get back to you with the results.
August 29th, 2009, 11:56 AM
By kgollnick in forum Sears Kenmore
Last Post: May 14th, 2011, 08:37 AM
By sjjak4 in forum Whirlpool/Roper
Last Post: September 8th, 2008, 09:15 AM
By t7044wa in forum Sears Kenmore
Last Post: November 6th, 2007, 04:43 PM
Last Post: November 7th, 2005, 07:57 PM
By albritton in forum Whirlpool/Roper
Last Post: November 3rd, 2005, 11:16 AM
