Our dishwasher started making this noise a couple days ago. It is coming from under the dishwasher itself, as gets much louder when you pull the lower front panel off. It washes fine, and you do not hear this during the draining or filling cycles.
I did a quick youtube video so you can hear the sound as well. I am guessing the garbage disposal motor possibly? I'd be glad to disconnect this part as we never put food in the washer, and it empties to the disposal under the sink anyways...... MDB9750AWS ![]() Last edited by Y2KGTP; September 8th, 2009 at 06:06 AM.. |
Its possibly either your chopper blade is bad and came out of place or your impeller is bad, or worst case the motor bearing went out.
Here's a diagram of your pump and motor assembly: ![]() You'll need to take off numbers 1,2,4,5,6,7 then you will be at your metal chopper blade, thats likely were its broken or out of place, possibly a seed or something hard that down in there and broke it. Also check your impeller#6 to make sure the plastic isn't chewed up either. Here's the repair manual for your model: http://www.servicematters.com/maytag...s/16021814.pdf Here's the impeller chopper blade assembly for your model: Manufacturer part number 6-919539 is RepairClinic item number 1469683 6-919539Here's the motor assembly for your model: Manufacturer part number 6-919963 is RepairClinic item number 1469749 6-919963Jake
Thanks much! I assume I can get to the pieces from the inside of the washer?
Yes, you can.
Finally had time today to tear it apart. And fixed it as well. Found this little plastic piece wedged between the blade, and the metal screen. runs perfectly quiet like before now.....
Excellent Y2KGTP, good job finding that.
LinkBack to this Thread: http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/16516-fixed-noisy-maytag-dishwasher-like-bearing-went-bad.html
| Maytag/Magic Chef/Admiral/Jenn-Air on Appliance Blog Forums | BoardReader | This thread | Refback | October 19th, 2009 09:45 AM | |
| Noisy In Spin Maytag Washer | kjr232 | Maytag/Magic Chef/Admiral/Jenn-Air | 4 | May 23rd, 2008 10:40 AM |
| Maytag dishwasher for parts | beginnersluck | Buy, Sell or Trade | 0 | February 25th, 2007 01:34 PM |
| Maytag model WU702 Dishwasher - NOISY | Mark Gammell | Maytag/Magic Chef/Admiral/Jenn-Air | 2 | August 11th, 2006 07:54 PM |
| Maytag Atlantis, No Spin, bearing or brake? | varontron | Maytag/Magic Chef/Admiral/Jenn-Air | 3 | May 1st, 2006 05:13 PM |
| Spray Arms not Spinning on Maytag MDB9600AWB Dishwasher | paulrhodes | Maytag/Magic Chef/Admiral/Jenn-Air | 1 | September 19th, 2005 03:52 AM |
