Old September 8th, 2009, 07:04 AM
Tampabay is on a distinguished road
Default Maytag Range MER5755QAW bake element
My oven stopped working yesterday (won't heat above 200) although the broiler and stove top are fine. I'm guessing that the problem is the element and want to test it but am not sure how to get to it. I've been working to remove the back of the range but it appears that I need to lift the cook top to get to a couple of screws. Can you tell me how to do that? Is there anyway to get to the baking element through the inside front of the range?
Old September 8th, 2009, 09:45 AM
Pull your range out from the wall, then take off the back access panel and you can ohm it and check voltage on it.
Normal ohms would be between 11-30 ohms. Unplug your range before ohm testing it.
You can use a volt meter to check for 240 volts across the element terminals when your oven is on.
To remove it:
Looks like your bake element is under your bottom oven panel, if so then take the screws out from your bottom panel #15 here:
http://c.searspartsdirect.com/lis_pn...8256-00003.png
Then take out your bottom panel#16, then #6 is your bake element, take that #9 screw out, then it should pull forward.
UNPLUG or TURN OFF YOUR BREAKER TO YOUR RANGE FIRST!
Here's the bake element for your model:
Manufacturer part#74011117 is RepairClinic item#1188695
Tampabay (September 9th, 2009)
Old September 9th, 2009, 07:10 AM
Thanks Jake! I used the multimeter on the bake element and that's the problem. I took the old one out and am waiting for the new part from Repair Clinic. This is the second time you've helped me fix an appliance (dryer was the other), so you've saved me a bundle. Many thanks to you and applianceblog!!
Old September 9th, 2009, 08:30 AM
Excellent Tampabay, good job finding it was the bake element.
Glad to help.
Tags
element, maytag, mer5755qaw, temperature
Maytag Range model #mer5755qaw Saber_jack Maytag/Magic Chef/Admiral/Jenn-Air 1 November 12th, 2007 11:18 PM
Kenmore bake element shorted - my mistake! wx_man Sears Kenmore 3 October 13th, 2007 04:20 PM
kenmore 790.95420302 Bake element won't work Raidermania Sears Kenmore 2 August 24th, 2007 11:14 PM
While checking new bake element for heat, arced and sparked! wkmccain Sears Kenmore 3 October 23rd, 2006 04:03 AM
GE Range: Replacing bake element rds1724 GE/Hotpoint 5 March 29th, 2006 12:53 PM
