Old September 10th, 2009, 09:23 AM
Barredo is on a distinguished road
Unhappy [FIXED] Admiral Washer doesn't drain completely
Hi Everyone,
This is my first post.
I have an "Admiral Heavy Duty Extra Capacity Plus" washing machine (can't find a model number but it's direct-drive) that stops draining with about 1/4 of the water left in the tub.
I took of the top end of the fill sensor hose and blew compressed air through it in case of blockages.
I took off the pump which seems to turn freely.
What else should I check?
Old September 10th, 2009, 06:15 PM
I think the Canadian Admirals are built by Whirlpool, but without a model# I'm afraid I can't assist you.
Jeff may be able to help you, he lives and has a appliance shop in Canada.
You can go to Jeff's q&a section here:
Question and answer forum entrance for Appliance repair helps
or You can email Jeff and ask him:
Appliance repairs, Appliancehelp, Appliances, repairs to dryers washers dishwashers fridges repairs microwaves ge maytag kenmore frigidaire westinghouse inglis, appliance how to take apart information, purchasing an appliance help, model number help,
Bottom of that link is his email address.
Old September 11th, 2009, 02:48 PM
Default Canadian Admiral washer
Thanks Jake,
I just located the Model # under the edge at the back of the lid.
It's an AP 44000.
My brother said it might also be a solenoid on the drain valve. But I can't find a solenoid. Do some machines have another kind of switch/valve?
Doug
Old September 11th, 2009, 03:37 PM
Appliance Tech - Apprentice
DTStephen is on a distinguished road
Is it draining at a normal speed?
Old September 11th, 2009, 04:13 PM
Red face
Hi Stephen,
I think so, I've never timed it. They say it should take under two minutes, correct? I've got it all apart, but I'll check it.
Doug
Old September 12th, 2009, 04:23 PM
Red face OK, Thanks.
Thanks Stephen and Jake.
I didn't know how to time the drain (I think the pump was running all through the final spin) but this time when I set-up the machine I took great care to 'straighten' the drain hose, to allow optimum flow, and it worked.
So it was probably the hose after all. Thanks Stephen for getting me to consider the hose again.
And thanks Jake for this WONDERFUL RESOURCE!
Barredo
Old September 12th, 2009, 10:42 PM
Thanks Barredo.
Glad you got it working.
Tags
admiral, doesn't drain completely, drain, washer
Estate Washer not draining completely friendlyhug Whirlpool/KitchenAid 17 August 13th, 2009 01:44 PM
Admiral washer will not spin (LNC6762B71) - correct model # ekoncepts Maytag/Magic Chef/Admiral/Jenn-Air 8 June 14th, 2009 10:27 PM
Kenmore 665.16529000 Won't Drain jadecamaro Sears Kenmore 3 February 26th, 2009 09:17 PM
GE WBSE3120B washer, won't drain nutopia GE/Hotpoint 1 July 9th, 2006 10:56 PM
Washer Doesn't Drain mcj39 Frigidaire/Electrolux 3 December 11th, 2005 11:07 AM
